Anyone seen the new shivs from saxo or quickstep in person or spy shots? Historically it's been a challenge to wire di2 on these things up front but it looks like the junction box up front is internal now - anyone seen the front end clear enough to know how?
In other news glad to see the forum back up - hopefully it sticks ..
Shiv di2 - saxo\quickstep
I thought so - but would it still be easy to pull the aero bars off and disconnect them ...
The photos don't show any junction boxes on the rear of their Shiv's however so is it possible to run a closed loop with no 3\5port junction - and for updating and charging, simply use a 3 port ew90 with an extra wire .... and attach it to the rear derailleur to charge and update?
Just ride ..
- Pokerface07
itsacarr wrote:I thought so - but would it still be easy to pull the aero bars off and disconnect them ...
That's what I do on mine.
Thanks for the tip! So I have to ask - since you don't have a EW90 junction in the system, or on the front .... if you travel with your tt bike, is it difficult to disconnect the front or do you have enough slack not to worry when you pull your bars off?
Just ride ..
