Life expectancy of shaved brake pads
Greg66
by Greg66
A combination of FC 808s and Simkins Egg brakes means I had to shave my pads to get the wheel into the calliper (ps: a serrated bread knife was the perfect tool for the job - a clean cut removing a layer of even thickness in a few seconds).
So now I have pads which are instantly worn and the limit line is much closer to the surface of the pad.
I've always assumed that the vertical groves cut into the pads are for cooling, or at least have some purpose. So if I cut those grooves a bit deeper than they were, why can't I run the pads until they are worn well past the limit line? I'm not going to run them all the way down to the shoes, obviously, but I can't see why I can't get a bit of extra life out of them.
Thoughts?
sungod
by sungod
the slots also help clear water, once they're worn away (as i found out on a wet commute) the pads take much longer to bite in the wet
there must come a point where too deep a slot weakens the pad, might increase risk of losing part of a pad under braking; depending on rim width and calipers they might also run out of travel and limit maximum braking force
no idea how significant these are, i'd guess more of an issue if you do descents needing heavy braking
assuming that's what the slots do, if you don't ride in the wet and don't need heavy braking you may as well leave the pads alone - no need for water clearing and they won't be getting too hot
Rick
by Rick
Personally, since I regularly get a decade or so out of a set of brake pads, I wouldn't worry about it.
wingguy
by wingguy
Keep running them and find out. Assuming the compound stays the same all the way down there shouldn't be a problem.
FYI though, SwissStop make thinner versions of all their road pads specifically for those wide rim/specialist brake combinations. Other companies may do as well.
eric01
by eric01
Just keep an eye on it and you'll be fine. Are you using the zipp gray pads? They do wear faster relative to a pad with a compound designed for alloy rims. A check pre or post ride and some common sense should tell you when they need replacement
tinozee
by tinozee
SwissStop makes a low profile "black prince evo" pad for use on wide rims on TT and other integrated brakes.
http://www.excelsports.com/main.asp?pag ... =1&minor=8
Might as well try the ones you shaved first, and if you need them you can always get these.
NiFTY
by NiFTY
I imagine they use one compound uniformly the whole way through, pads should last a long time regardless.
Greg66
by Greg66
Thanks all. Reynolds Blue pads on my tri bike. Won't be getting wet weather use (unless I am unlucky on a race day). I will keep an eye on them and report back if I have problems.
