It is currently Sun Apr 23, 2017 11:18 am
Post new topic  Reply to topic  [ 19 posts ]  Go to page 1 2 Next
PostPosted: Fri Jan 16, 2015 12:32 pm
Hi I just bought a Cannondale slice RS, and have yet to receive it. Just wondering from owners, is it possible to fit an internal battery into the seatpost/frame?
Will ilinks fit through the headcap into the steerer tube for brake routing?
Can you show me how those of you that have tidied up your front ends have done it?
ANyone know rim/tyre clearance.
Cheers
Evo 5.13kg SL3 6.77 Slice RS 8.89 viewtopic.php?f=10&t=110579" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
PostPosted: Fri Jan 16, 2015 6:42 pm
Not in the seatpost as the RS uses a knife profile seatpost. Also unless they changed the way they wired up Di2 there will be a mess of wiring at the stem. I actually had to send pictures of an RS in my shop to Cannondale techs so they could figure out how to clean up their mess of wires. Cannondale can likely send you the images I sent them. Tire clearance in the frame won't be near the issue as getting larger tires through the brake set. It is a very tight fit. I am not sure about iLinks as there are a couple of hard curves coming from the bottom of the steerer into the brake sets, they supply their own version of a brake cable noodle to get everything to fit, there is not a lot of room inside the steerer tube.
PostPosted: Sat Mar 28, 2015 3:12 pm
Hi. Curious if you got your Slice RS and installed Di2 yet? I'm about to do the same so may run into the same headaches! Thx.
PostPosted: Sun Mar 29, 2015 2:14 pm
Yes all installed. Don't think there is anywhere that will take an internal battery. I have the battery under the BB. I have 6870/9070 mix. I am running pro missiles and have all the junction boxes in the extensions of the bars, so there is only one cable leaving the bar/extension setup and entering the frame. The B junction is also in the extensions and I dremeled a window out of the side of an extension so I can see battery level and access the button. I will post photos of my build soon. Its not an easy bike to build.
PostPosted: Sun Mar 29, 2015 2:59 pm
Could you not shove the battery in the downtube? That's what I did with my Plasma 3...
PostPosted: Sat Mar 11, 2017 12:51 am
Anyone know the answer to this - bought the frame, have an internal battery - if I can avoid buying an external battery as well I'll be stoked.
PostPosted: Sat Mar 11, 2017 10:29 pm
Maybe if you strip the battery of the casing it could be possible to fit the cells and connection part through the hole for the cable guide in the bottom bracket, and through the hole into the downtube. The openings are however not very large...
PostPosted: Sun Mar 12, 2017 12:18 am
What about through the head tube with fork removed? That's how I did it.
PostPosted: Sun Mar 12, 2017 12:41 am
I will report back once the frame arrives. I wonder if the front end of the frame is filled in behind the external steerer - anyone who owns one care to comment?
PostPosted: Sun Mar 12, 2017 2:45 am
I think the headtube may be your best chance, but you'll have to pop out the headset.
I have a slice RS and it won't fit in the seat tube or go through the BB - even with bearings removed but I am yet to try removing an outer casing and installing it that way. Let me know if you have success. They are a great riding frame.
Only other bit of input is if you find you need to go longer at the front you can get longer bolts and run all the spacers together even though they say 40mm is the biggest extension that is safe I am running 60mm for ages now with extra long bolts and it is completely safe.
PostPosted: Mon Mar 13, 2017 3:17 pm
It's hard to get the internal battery to fit anywhere in the Slice RS. But I've managed to do a DIY solution with the battery in the TT extensions, works really well.
Actually had an even harder time getting the Di2 junction box to fit somewhere it was out of the way but accessable to charge battery. Started with trimming the casing enough so that I could get it inside the TT extensions, but I got all the way down to the circuit board, and in the process managed to destroy the junction box. On the second try I stuck it beneath the saddle which was a great solution. Drilled a hole for the cable to go through the seat post.
PostPosted: Mon Mar 13, 2017 6:52 pm
Great info as usual - thanks!
PostPosted: Tue Mar 14, 2017 7:35 am
I also have the battery in one of the extension. In the same extension I have a 4-port junction, connecting the shifter and battery. This junction is connected to a ew90 junction located between the extensions, right behind where I hold my hands. Another 4-port junction connects the ew90 to the other shifter and the single cable going into the frame.
Of course this limits what kind of extensions you can use, as they need to have a long enough straight section for the battery. Also, extensions have thicker walls, making it a tight fit. I have had success with Zipp carbon race and Zipp aluminum evo 70 and 110.
Going through the headset might work, but I'm not comfortable in the idea of needing to remove and reinstalling the bearings if/when something goes bad.
I would like to try the new bar-end junction in one of the extensions, but of what I have heard the outer diameter of that junction is larger than the inner diameter of typical extensions.
PostPosted: Tue Mar 14, 2017 7:37 am
Can you give more details about the drilling and the routing down the seat tube?
PostPosted: Tue Mar 14, 2017 3:45 pm
I drilled from the top down through the seat post head, only a small hole big enough for the cable, then cut and spliced the cable. I think the best way to show is with pictures.
There are no new unread posts for this topic. 2012 Cannondale Slice 5 VS 2014 Stradalli Phantom II
Alpine318is
Tue Mar 14, 2017 7:43 am
jekyll man View the latest post
There are no new unread posts for this topic. Zipp Vumaquad for Cannondale bb30 question
abrown3mtg
Fri Jun 17, 2016 2:28 am
Juanmoretime View the latest post
There are no new unread posts for this topic. Josh is putting on a master class on rims and tires @ slice blog
uraqt
7
980
Sun Jun 26, 2016 4:39 pm
velomane View the latest post
There are no new unread posts for this topic. what do you think of cannondale evo 2017??
Dokas
40
10754
Thu Nov 03, 2016 6:03 pm
illskittlz View the latest post
There are no new unread posts for this topic. What Colour is My Cannondale?
Valbrona
Fri Jun 03, 2016 1:46 am
BRM View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], ericoschmitt, Google Adsense [Bot], jlmcabral, kgt, NoMütze, Ritxis and 24 guests
