White painted hubs - options?
RedRacer
by RedRacer
I am searching for light weight white hubs with 20/24H drilling. It seems like Tune is the only option but they aren'y my favourites.
Suggestions?
synthesis
by synthesis
DT Swiss 240s?
liam7020
by liam7020
DT Swiss 180
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
hmai18
by hmai18
Get the hubs of your choice and have them painted.
madcow
by madcow
The new DT180 are black, but last years were white, you may find some closeouts on those. The only other one that pops into mind are Tune.
tmr5555
by tmr5555
Deleted, wrong topic.
btompkins0112
by btompkins0112
Bike hub store has a lot of options also....
mike
Resident Pro
by mike
Tune for sure.
RedRacer
by RedRacer
madcow wrote:The new DT180 are black, but last years were white, you may find some closeouts on those. The only other one that pops into mind are Tune.
That is what I discovered, plus the white DT180s are ugly....maybe the logos can be removed? Still the price is hideous!
The Tunes look good and the weight is nice but the freehub makes so much noise that ear plugs are required. Wish they would fix that.
Jaroslaw
by Jaroslaw
Just a heads-up, Tune hubs colours tend to fade with time.
I have seen red hubs turn kind of pink-ish with time.
Not sure if the white would yellow a bit, maybe not, but I think you should be aware :)
NiFTY
by NiFTY
Bontrager make white hubs, find some cracked aeolus rims and steal the hubs? They are 18/24
StradaJon
by StradaJon
I think the Tune hubs are powder coated(?) so no chance of fade there.
Also, Acros make white hubs
http://www.acros.de/PRODUCTS/HUB/-54-ROAD/
Strada Hand Built Wheels
http://www.stradawheels.co.uk
