Switching from Bont with ISP frameset, wich shoes ?
HI,
I'd like to try something different than my Bont's A1.
BUt the challenge is to find some shoes with very low stack height, since my ISP is cut exactly for the fit on Bont shoes. I can raise the saddle by maybe 4-5 mm, but not much more.
Any suggestions ?
Thanks in advance
Louis
Any suggestions ?
Thanks in advance
Louis
LouisN wrote:HI,
Any suggestions ?
Thanks in advance
Louis
Hi Louis, as you mentioned that you can raised the saddle by 4-5mm, I doubt that the difference of Bont A1 stack height with other shoe is more than 5mm. Unless you are using Speedplay Cleat on Bont (without Adapter) and changing to a shoe which requires adapter for the Speedplay Cleat. My experience from Bont A1 Speedplay sole to Bont Vaypor with Adapter for Speedplay is about 5mm. For other shoe might be more than 5mm.
Hope this help.
A.W
You could try a pair of D2 shoes. They have very thin soles.
I finally went for a pair of Northwave Extreme 3S.
Very happy with the purchase.
I have to rise the seat mast by 6-7 mm to have the same height.
It's ok with the Ritchey stubby, I put a carbon spacer made out with some ISP "slices".
I wanted to try the Woodman IT seat mast but it's pretty short, so I don't know if it'll fit solid now....
Louis
Louis
