NEW Campagnolo powermeter released
No info? You gotta give us more than that otherwise your just teasing!
- Moderator
4 hole s type?
Using Tapatalk
Nefarious86 wrote:4 hole s type?
Yes, it A new version of Power2max Type S With 4 hole chainrings, 2015 version.
See all my bike h e r e
- mvacolnago
The new 4 bolt standard is Fugly, but I get it, 50/34 , 52/36 , and 53/39 on the same spyder is very appealing.
That is mighty pretty!
Hmmm... I know that carbon can't really be used as the spider for a power meter, hence the alloy spider. But look at those huge slots in it. And how little material is actually making its way around those slots to where the rings actually bolt on. That cannot be good for overall stiffness of the crank. Compare that to the solidness of the beefy carbon all-in-one crank of the standard 2015 Super Record. Seems like there still might be some issues to work out here. Time will tell, but I like the looks of it at least. Wonder what the purpose of those slots are anyway? It must be something to do with how the strain gauges react (admittedly that's just a wild guess on my part), because it can't save enough weight to counteract the extra strength that I would presume is lost due to the cutouts.
