Edco Monoblock Cassettes
Hello,
has anyone already tried EDCO Monoblock Cassettes?
http://www.edco.ch/products/accessoires/cassette.html
Could be an alternative to SRAM - if durability and shifting quality are all right...
They even fit on 10speed cassette bodies and are offered in a wider gear range.
Thanks,
B.
Thanks,
B.
If shifting quality is all right yes - if not...
Edit: There are also 11s cassettes for 10s wheels from Token:
http://www.tokencycling.com/products.ph ... _parent=65
Any weights or experiences for the Token cassette?
Edit:
CNC 11 SPEED
CROMO CASSETTE
FOR 10 & 11 SPEED WHEELS
11-25T: 170g
11-28T: 185g
Edit:
CNC 11 SPEED
CROMO CASSETTE
11-25T: 170g
11-28T: 185g
- wheelsONfire
That's an interesting choice. I was figuring if i should go ahead with Miche Supertype or Tiso cassette.
Edco probably won't creak, i guess Token will (carbon cluster).
Hm,.... this was great
Bikes:
Open *UP* (2016.04.14)
Interesting that they fit 11sp on a 10sp freehub, which is 1.8mm narrower. I wonder if there will be clearance problems with the spokes or frame?
- wheelsONfire
It seems you should have easier to tune for no chain rub.
I'm going to get this cassette for sure
Bikes:
I have used Edco 11s for my 10 speed wheels. The fit very good, they are lighter than Duraace around 15grms. The only drawback if I can call it a drawback is that when you shift it is a click more noisy than shimano, because it is one piece and it makes an echo. During riding the noise level is exactly the same. It needs to readjust your RD, but I didn't face any clearance problem. If you don't have any choice for a new freehub, it is a very good idea. When you order it don't forget to,order the extra lockring for the 10s hubs. ( I forgot it)!!!!!
kx_1, sounds good, where did you get the cassette and for how much?
kx_1 wrote:I have used Edco 11s for my 10 speed wheels.
Directly from them. I send them an email. Because I could find a solution for my RZR reynolds wheels. The price if I remember correctly it was like duraace.. I will check it and come back....
As a dutch distributor I can provide you this product aswell, just contact me. And we'll arrange it.
While shipping is pretty expensive (around $50 USD on a quick check I did) it looks like you can order from their online store: http://www.carbonwheelsshop.com/accesso ... ettes.html
