Edco Monoblock Cassettes
Available in the US from Reunolds here, only 11-25 at the moment.
http://www.reynoldscycling.com/shop/ind ... itm_pk=836
kx_1 wrote:I have used Edco 11s for my 10 speed wheels. The fit very good, they are lighter than Duraace around 15grms. The only drawback if I can call it a drawback is that when you shift it is a click more noisy than shimano, because it is one piece and it makes an echo. During riding the noise level is exactly the same. It needs to readjust your RD, but I didn't face any clearance problem. If you don't have any choice for a new freehub, it is a very good idea. When you order it don't forget to,order the extra lockring for the 10s hubs. ( I forgot it)!!!!!
Thanks for the feedback!
And could you use this extra lockring to use with duraace 11s cassette on 10s hub ?
Or the edco cassette as also a deport on the big cog ?
Thanks
eric01 wrote:Trying to understand exactly how the Edco cassette achieves 11sp on 10sp hubs... Am I correct in understanding that the smallest gear protrudes a little further out towards the dropout?
Speaking of token, has anyone found a source for this cassette? I did some googling and can't seem to find online.
According to BIKERUMOR review, yes, the smallest cog moves towards your drop out. That is a 'NO GO' for me.
Token is here;
http://www.tufonorthamerica.biz/index.p ... ts_id=1277
eric wrote:The small cog is already as close to the frame as it can be. They have to move the large cog over towards the wheel.
According to BIKERUMOR review the smallest cog is moved towards the frame.
http://www.bikerumor.com/2015/02/02/edc ... s-cycling/
Would have been sweet if EDCO would have 'split the difference'. Use the XTR cassette off-set idea combined with pushing the smallest cog towards the drop out. Consume some of the space by off-setting towards the spokes and consume the rest by off-setting towards the drop out.
Would keep the cassette (and r. der.) away from the spokes and wouldn't crowd the drop out.
Oh well, time to get the file out and go after my free-hub.
My Edco 11spd cassette just arrived at my house. Unfortunately I am deployed again so won't get to ride it before April. I am pairing it with DA di2 11spd. Once I get a chance to ride it I will let everyone know how it works out.
Hi.
Thinking about purchasing a EDCO Monoblock Cassette, has anyone tried one?
This could be an alternative to me having a new freehub body fitted to my Bontrager Aeolus 3 D3 Clincher rear wheel and fitting an 11speed cassette onto a 10speed freehub.
What is the shifting quality like say to a Dura Ace Cassette, I shall be using the EDCO with DA 9000 Groupset?
Is there any clearance problems with the spokes or frame? My frame is a Trek Madone 6.9SSL.
Thanks.
Thanks.
Another possible option is the Wheels Mfg Campy Conversion cassette. It's nominally spaced for Campy 11sp which is slightly different than Shimano and Sram. However many people claim all three are compatible. Of course the Wheels cassette may not match the Campy standard, and if it's out of spec the wrong way, may not work as well.
As far as I know, no one has tried this yet.
OTOH a new freehub is probably cheaper, especially if you fit it yourself.
@relanium. I have used Edco 11s for my 10 speed wheels. The fit very good, they are lighter than Duraace around 15grms. The only drawback if I can call it a drawback is that when you shift it is a click more noisy than shimano, because it is one piece and it makes an echo. During riding the noise level is exactly the same. It needs to readjust your RD, but I didn't face any clearance problem. If you don't have any choice for a new freehub, it is a very good idea. When you order it don't forget to,order the extra lockring for the 10s hubs. ( I forgot it)!!!!!
eric wrote:Another possible option is the Wheels Mfg Campy Conversion cassette. It's nominally spaced for Campy 11sp which is slightly different than Shimano and Sram. However many people claim all three are compatible.
I'm currently running a campagnolo 11 cassette on SRAM 11 - shifting is perfect and running is silent all the way through the block. They are absolutely cross compatible, the spacing from the centreline of each cog is identical.
As for Edco, we've sold them for the last couple of months with no adverse comments yet, apart from the locking being quite a tight fit in the threads. I've been surprised by the number of people who still have 10sp only wheels to be honest.
This may not work with all wheels. Some hubs have DS flange spacing pushed out as far as possible for 10sp as that makes a stronger wheel.
It may work with larger cogs (i.e. 27t and up) where it doesn't work with smaller ones.
This is not quite correct. On most bikes there is room for an eleven speed cassette that is closer to the frame. Remember that the cogs are closer together with 11-speed than 10. The 11-speed cassette is only a tiny bit wider than a 10, not a full cog and space wider. Most frames have room for that couple of mm. If you replace the freehub body to fit an 11-speed cassette on a previously 10-speed hub, you will still be putting all the extra cassette width on the frame side, not on the hub side of the cassette. I have done this many times, and it has always worked.
Robert
