Losing weight bike
tim19910510
Resident Pro
by tim19910510
Hi everyone,
I would like to ride with a more aero frame, but this makes my bike +-7.1kg instead of 6.8kg. How can I save weight without anyone seeing it?
I need to the brands from my team. So was thinking for example mechanical instead of elektr groupset, lighter cables and titanium bolts. Anyone other suggestions?
My bike is the Ridley Noah SL, with campa elek, deda, look pedals and san marco saddle.
Thanks in adavance :beerchug:
sungod
by sungod
powercordz cables can certainly save a useful amount, but i would not use them if you'll need to remove/refit mechs/brakes during the season, reclamping risks damaging the inner fibres
ti bolts will only save a little
why not lighter post/saddle/wheels/bars/stem/whatever with decals/paintjob to match whichever brand(s) the team needs them to look like?
tim19910510
Resident Pro
by tim19910510
Powercordz good idea. Thx.
Because sponsers often come to races, and they will notice for sure...
Reason: No need to quote the above post
sungod
by sungod
you can save some more with nokon/similar cable outers (be sure to use powercordz liner, not the nokon supplied one)
bottle cages and quick releases are other opportunities
bm0p700f
by bm0p700f
300g will not slow you down so why bother.
sungod
by sungod
bm0p700f wrote:300g will not slow you down so why bother.
this is weightweenies, you are talking blasphemy!!!
CXrider
by CXrider
the topic starter is a pro, on world tour level, every gram counts
mattr
by mattr
LOL, you'll have to let half the peloton know that.
You know, the ones who have over weight bikes that slow them down.
Aero, fit, comfort, biomechanics, maintenance all give far greater gains than 300g.
tim19910510
Resident Pro
by tim19910510
Thx everyone! Other suggestions always welcome...
BRM
by BRM
strip all the paint
:smartass:
tim19910510
Resident Pro
by tim19910510
BRM wrote:strip all the paint
:smartass:
That is a bit to much weightweenie for me! :D
mattbus73
by mattbus73
Although I'm no expert in the matter, however I've been on a similar exercise trying to shed some fat off my ride.
Without getting into the specifics and boring everyone to tears, or commandeering this thread, I'm also at 7.2kg mark and only have left to swap out for Ti bolts and install the Powercordz into the Nokon housing.
I was considering using zero gravity brakes too.
All of which should break the 7keg mark. Then I'll be happy.
Best of luck Tim.
Raineman
by Raineman
lightweight bar tape and a narrower handlebar, you will also be more aero too.
addictR1
by addictR1
Which brand have the lightweight bar tapes? I'm looking to cut weight down as well. Need some stuff handlebar 42cm under 180g possible?
jamesbass
by jamesbass
- Lighter skewers possible?
- Alligator iLink Cables
- Lighter seatpost possible?
- Are you allowed to use Veloflex Record tubulars?
- Chop handlebars down / less bar tape / narrower
- Lighter BB?
I guess, if you're sponsored, can you contact each sponsor to get the lightest components they have? Can you convince them to make you customized lighter parts for you?
