Best Chainrings Upgrade
coneill0422
by coneill0422
I am looking to upgrade my chainrings for my S-Works crankset. I decided to go compact (50/34) which I had on other bikes in the past. I was wondering about some of the better ones out there. I was thinking about either getting the CT2 Stronglinght's, Cannondale MK5's, or the Praxis. I also like the blacked out look and I got a new S-Works black carbon 110mm spider, anyone have any feedback?
kij
by kij
I'm liking the Praxis, nearly as good as the Shimano. A good weight savings with only a slight performance hit.
WheresWaldo
by WheresWaldo
Of course nothing shifts like Shimano, but the Praxis rings are a close second. I have had more trouble with chains and not chainrings. Found that the Shimano and KMC chains appear to shift better than any Wipperman or other chains I have used.
53x12
by 53x12
Can't go wrong with either Praxis or CT2 Stronglinght. Just see what you find the best deal on. I have used both and had good experience with both.
eric
by eric
I was disappointed with my Praxis rings. They don't shift notably better than the Sram red/black rings I was using before, and the big ring is noisy. This is with a KMC chain. Their weight is identical to the Sram rings.
I may try the CT2s next.
jimaizumi
by jimaizumi
I also support the Praxis chaining... While my Stronglight CT2 rings were noticeably lighter versus the Praxis, the Praxis shifts much better.
THE PAST: 2005 C'dale R700, 2006 Spesh S-Works Tarmac Gerolsteiner, 2009 Pinarello Dogma FPX My Way, 2011 Time RXR VIP
THE PRESENT: 2016 Colnago C60 ST01, 2017 Wilier Cento 10 Ramato, Cinelli Gazetta
THE FUTURE: :mrgreen: :mrgreen:
Pottsy
by Pottsy
Get the Praxis.
I switched to them from S-Works chainrings & shifting is soo much smoother & faster.
ProEvoSLTeamHighMod
by ProEvoSLTeamHighMod
WheresWaldo wrote:Of course nothing shifts like Shimano, but the Praxis rings are a close second. I have had more trouble with chains and not chainrings. Found that the Shimano and KMC chains appear to shift better than any Wipperman or other chains I have used.
All of this.
Praxis rings are 2nd to shimano, a huge improvement over sram (stiffer, better ramping / tooth profiles) - and reasonably light.
Also, no garbage wipperman chains... shimano or kmc chains, and should be problem-free.
spdntrxi
by spdntrxi
another vote for praxis..
2024 BMC TeamMachine R Building
2018 BMC TImeMachine Road
2002 Moots Compact-SL- getting aero look makeover
2023 Pivot E-Vault - completed project, full Xplr package
dereksmalls
by dereksmalls
Go full bling and get Fiberlyte, this is weight weenies after all!
tomyboy123
by tomyboy123
Praxis Works--- :thumbup:
Marin
by Marin
Maybe try oval ones?
I have a set of Doval rings coming.
coneill0422
by coneill0422
Thank you everyone for your input I ended up getting some CT2 Stronglight's the black look top notch.
richard@lbrc.org
by richard@lbrc.org
Praxis always look good, happy with my CT2's as well though. Pics http://lbrc.org
drainyoo
by drainyoo
Can't go wrong with the Extralite Octaramp RC2. Love mine and the set is under 100g.
