clavicula, what BB in a collage C60?
Bely
by Bely
Hi there, wondering if anyone can help, as after searching and trying to understand, I am still confused. Which bb should I get so that my clavicula crank can fit onto a colnago c60. Also for my Canyon Speedmax tt.
Any help would be much appreciated.
Thank you
Current
Festka Scala | Pego Respo | English V3 | Colnago EPS Erik Zabel | Colnago V4rs
Incoming
newforker
by newforker
For the C60 you will need what THM calls "Shimano Press Fit", which is essentially a BB86 but with a 30 mm inner diameter rather than a 24mm.
No idea about the Canyon however.
madcow
by madcow
The Thm Shimano Press Fit should be the right bb for both of those bikes. I know it is correct for the C60 as I've built a few of them lately. The top end Speedmax also uses the same bb, I assume all the other models do as well.
danbjpa
by danbjpa
Excuse for the OP by hitchhiker on your topic but my doubt is similar. I'm BB noob, so don't fire me if my question is dumb.
I have a wilier zero.7 (BB386) frame and planning buy a Clavicula M3. My frame came with bearings and adapters.
Question:
I need buy a THM BB386evo or the bearings that come with frame works ok?
(i'm using a campy crank at moment)
---- Sorry my english
Denavelo
by Denavelo
If you're planning on buying a THM crank, you need to also use their BB setup.
Rob English "Mudfoot" 29er | Focus Izalco Max | Firefly #194 Stainless XCR | Firefly #277 | Neilpryde Bura SL 11.9 | Crust Evasion Lite
danbjpa
by danbjpa
At doubt I had bought the BB too. good to know that was not in vain.
Thanks!
