Super Record 4 arm chainset initial views...
Harmitc
by Harmitc
Totally agree that the flexing between the rings would more likely give you a front shifting problem, but so far I've been very impressed with how cleanly the derailleur picks up the chain from inner to outer ring. That's been noticeably better than my old SR.
The set up tool that Campagnolo is selling makes alignment a 5 minute job, and gives consistent position.
Personally my experience of chain rub is more likely bottom bracket flex than chainset distortion. But just my opinion as I'am not familiar with the frame in question.
audiophilitis
by audiophilitis
Can the Campy setup tool be used for non-Campy cranks/chainrings, i.e., Clavicula? The tool is really intended for proper alignment of the 2015 FD, correct?
Harmitc
by Harmitc
It just sits on the chain ring and has an engraved line that allows you to line the cage parallel to the ring while maintaining the correct clearance. Obviously it's biased to Campagnolo but might well work with another chainset running a Campagnolo front mech. I think it's a new tool biased towards 2015 product.
TimW
by TimW
I used the tool on a 2014 Record front mech with a Rotor chainset and it worked well. The tool has been around a little while I think, although not many places have it.
markyboy
by markyboy
where can I get this alignment tool ?
Colnago arabesque campagnolo super record 12
Colnago c64
Cinelli zydeco grx di2
markyboy
by markyboy
I have tried google but not much hope
Colnago c64
Harmitc
by Harmitc
Mine came via Chickens in the UK. Look for Chickencycles.co.uk. I think they only sell via dealers not direct.
TonyMM
by TonyMM
What is the part-number of this campagnolo alignment tool ?
Any picture of it ?
Harmitc
by Harmitc
Part Number UT-FD020
There's not much to it but it makes alignment quick and easy.
TonyMM
by TonyMM
Thanks !! how much does it cost ?
Harmitc
by Harmitc
Where are you? What country? In the UK I bought it as part of my EPS Group.
TonyMM
by TonyMM
In Germany.
Is it part of the group or do you have to order it on top ?
Harmitc
by Harmitc
Order it separately. It's pretty cheap but I didn't price it individually as it came as part of the packaged price.
TimW
by TimW
markyboy wrote:I have tried google but not much hope
markyboy, forget about the UK distributors. I ordered mine from here, just drop the guy an email in english and he will sort it. I think they cost about 12 quid in all and took about a week. Found it on another thread.
http://www.campagnolo-sirer.cz/naradi/n ... gnolo.html
Cheers
ultimobici
by ultimobici
What Chainset are you using, compact or standard?
