Sorry again for this very late reply! I've been non-stop with xmas shenanigans.
So here is an update: shortly after my last post I called up the shop. The reason they hadn't replied to my earlier emails was because they were still waiting on the manufacturer to get back to them. So they called the manufacturer up there and then, and spoke to higher management, and they agreed that this issue had gone on long enough and so agreed to give me a full refund! I am very happy
OK so based on some of your questions and suggestions I feel like I haven't explained a few of my previous point properly. So in regards to the internal diameter of the seat-tube. The frame specifications are for a
27.2mm seatpost and I was using a
27.2mm seatpost and the manufacturer was offering me a
27.2mm seatpost. No doubt in the past manufacturers have designed frames to take a 27.4mm post, but this is not one of them. Also, I said the average diameter was approximately 27.4mm, but what I should have said is this:
T 27.32, 27.52, 27.43 average 27.42
B 27.60, 27.50, 27.42 average 27.51
So the T means Top, the top of the seat-tube, and B means Bottom, a little further down the seat-tube. As you can see, I took 3 measurements for T and B, at different angles to get an average. The important thing to take away from this is the relatively LARGE range in the diameters. So yes, I could have attempted to use a 27.4mm post, and no, it would not have worked.
Here is another set of measurements I made with 2 of my other bikes to compare to; note the consistently smaller range:
Specialised Langster
T 27.34, 27.28, 27.28 average 27.30
B 27.25, 27.34, 27.40 average 27.33
Cannondale F600
T 27.22, 27.39, 27.30 average 27.30
B 27.23, 27.33, 27.26 average 27.27
There is another point that I need to make, if I haven't done so already. Something inside the seat-tube was chaffing the crap out of my seat-post. I'm not sure how to upload pictures on here, when I find out, I'll post one! And yes, the frame is off the peg, although there is an option for a custom build.
As to why I don't want to name the shop or the manufacturer; my worry is that my experience will be taken out of context. The reality is that both shop and manufacturer have a good reputation, else I wouldn't have bought what I bought. And in all honesty, everyone gets a few hiccups, even the ones with a good reputation. Also, the shop I bought it from don't know me personally as I had them post the frame over to me. So in their eyes, I could have been some random punk trying to scam or mislead them, something I reassured them I wasn't.
I guess the message to take away from this, now that it is all over, is that you should persevere when your gut instinct is telling you not to settle.
