Bike Frame Protection Stickers
eric01
by eric01
I have a black frame and just put a strip of electrical tape on the head tube. Found a roll that matches the same gloss of frame. Blends in well. Cheap too!
dunbar42
by dunbar42
Cable housing donuts look better IMO. Search ebay.
Method01
by Method01
Won't they scratch too (in the long term)? If sand gets between the donut and frame for example.
jefflhm
by jefflhm
even brand new car break down & get scratches after a while....
put your bike at home dont ride, it will forever be scratchless.
if you need to ride. cycle a tank.
DWatkinsBSB
by DWatkinsBSB
jefflhm wrote:even brand new car break down & get scratches after a while....
I shall not flame.
:beerchug:
mattr
by mattr
jefflhm wrote:If you need to ride. cycle a tank.
You do realise that even a few days riding in grubby conditions can lead to the cables taking the paint finish off your frame (down to the metal/CF) once this happens the cables will tend to sit in their nice custom ground groove. And continue wearing the frame away.
I've seen a few frames actually go through. Usually on the head tube and tops of the seatstays
I'm guessing you ride a tank.
mattr
by mattr
Method01 wrote:Won't they scratch too (in the long term)? If sand gets between the donut and frame for example.
Not really, the doughnut moves around a lot and is also far far softer than the paint. Easier to clean as well. Still not as good as the stickers.
wilwil
by wilwil
Ive found lots of this protection tape yellows very quickly which looks horrible on a white frame especially. 3M Helicopter tape does. I found some that has a backing and a front protector that peels off once its stuck on. Its German, made by Hyperlex. Tesa 54994 Helicopter tape is better than 3M.
Method01
by Method01
I always use BBB stickers and they've never turned yellow.
dunbar42
by dunbar42
Just clean that area every week or two and it'll be fine. Much better than bare cable housing sitting on the head tube. I think the stickers look so ugly so it's not an option on my bikes. Plus, the stickers will need to be repositioned if you make enough of a change to the stem/bars or cable housing length.
Butcher
by Butcher
Poor quality protection stickers yellow and look ugly. A good gloss/matte clear sticker cannot be seen 6 feet away, so I do not understand what people are talking about being ugly.
The only downside about a good clear sticker is the weight [that can only be mentioned here without being scoffed at].
