which fork?
jhamlin38
by jhamlin38
I'm planning to rebuild my steel Fondriest frame. I love the fit, the feel about it. The flex of the frame "WORKS" awesome. however, the fork, must go. downhills and climbing out of the saddle are what keep this bike from being almost perfect.
I need a 1-1/8" fork, all carbon.
should I go with 3t Ridgida, or an enve?
or can someone direct me to some recently written reviews or posts that do a nice job reviewing a particular road fork?
thanks all
sungod
by sungod
unfortunately the forum search doesn't allow 'fork' as a search term
fwiw last year i swapped to the enve 2.0 fork (from columbus minimal), and it was a huge improvement...
no more understeer on fast/aggressive cornering
ok on most road surfaces, only get buzz on really rough tarmac
no noticeable flex when pushing/pulling on the bars
i'm c. 77kg
tantra
by tantra
The Enve 1.0 is an awesome fork. Light, reasonably stiff, with a wonderful ride quality. Do you know the offset (rake) of your current fork? If you like the handling of your bike with the old fork, you should keep the offset the same. More offset gives faster turning which can lead to squirreliness. Less offset gives more stability but with slower turning and more sluggish handling.
Frankie - B
Admin - In the industry
by Frankie - B
I believe that this is the other way around, Tantra. More offset (45) stable at speed, slower turns. less offset (43 and less) faster steering. but ofcourse that all depends on the angles of the frame as well.
If you want to see 'meh' content of me and my bike you can follow my life in pictures here!
tantra
by tantra
Frankie - B wrote:I believe that this is the other way around, Tantra. More offset (45) stable at speed, slower turns. less offset (43 and less) faster steering. but ofcourse that all depends on the angles of the frame as well.
No, it is correct as written. More offset (rake) = less trail = faster turning. See Lennard Zinn's discussion: http://velonews.competitor.com/2004/12/ ... ffset_7322.
