Shimano D-Fly w/Garmin
upside
by upside
Nope.. just Dura Ace
grouk
by grouk
no they havent
i will open my shifter soon to see if inside is any circuit, but outside there is nothing :(
MNX1024
by MNX1024
Darn it, looks like I'll have to get another Dura Ace groupset instead of Ultegra. Hoping to save some money, but spoiled with those buttons. :(
spdntrxi
by spdntrxi
MNX1024 wrote:Does anyone know if the 6870 shifters have those button up top?
No they do not.. I hope they update
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
WheresWaldo
by WheresWaldo
No
Timmy269
by Timmy269
Yesterday I installed my D-fly but my Garmin 810 doesn't find the Di2 system.
The software of my garmin is 3.40
upside
by upside
You will have to do the firmware update with Shimano first.. then do the new update with Garmin and you should be set!
Timmy269
by Timmy269
I updatet the firmware of my groupset and still my garmin can't find the di2 señor
strangely
by strangely
@Timmy269,
Mine was tricky initially also, but I succeeded after a while. Try to search for it with the Garmin after just after performing a shift. If this doesn't work then I think what solved it for me was performing the search after just having re-installed the Di2 battery, or the connector to the D-fly. I think it only pairs for a limited amount of time after a shift (wakes it from sleep) or power up.
Timmy269
by Timmy269
It works now. I connected my di2 again to my pc and updated the sensor. After that it connected.
LeviR
by LeviR
sun wrote:Anyone using this on the Edge 510? If someone can post a screenshot of what the gear indicator looks like, that would be great.
It works on Garmin Edge 510.
Quattroporte
by Quattroporte
Dredging up an older thread to ask:
Has anyone tried mounting the D-Fly in a location other than the DS chainstay and found a location where it did not work? Mostly interested in internal mounting locations and paired to a Garmin.
goodboyr
by goodboyr
Works fine inside my seat tube under internal battery.
dha
by dha
Adding to my setup. Will run in the seat tube going on the reports here
MNX1024
by MNX1024
I've mounted mine within the bottom bracket along with my internal junction. No issues at all.
