Shimano D-Fly w/Garmin
- WheresWaldo
- in the industry
Actually the shortest SD50 cable is 150mm, and every 50mm until 1000mm then 1200mm and 1400mm.
Benno wrote: like the thought of a gear indicator but not enough to have some cheesy thing zip tied to my seat stay.
Love this quote
(In the same position myself - it's like they bought out the rubbish version just so people will upgrade next year for the internal version
spdntrxi wrote:same here.. no looking down and back anymore
Don't mean to be rude but why on earth do you need to look at your gears to know what gear you're in? Just turning your legs will tell you all you need to know.
cycling / nature / music
I put underneath my k-edge xl mount as shown in the link, maybe I will try to hide it inside the frame further down the road but now it won't bother me that much.
viewtopic.php?t=129433
Miller wrote:spdntrxi wrote:same here.. no looking down and back anymore
I feel the same way. It's like L/R balance (for the most part), you have all this data... and then what? What do you do with that data that's in any way meaningful?
Do the 785's have secret buttons?
BeeSeeBee wrote:Miller wrote:spdntrxi wrote:same here.. no looking down and back anymore
Later on you will be about to see where in the stroke the power is applied.. Like a vector on the screen. If you wanted to see if you stayed in a certain gear longer or shorter on a particular climb.. There is a whole bunch of stuff that I want to take a quick look at... Might not look at it every ride but nice to know
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
?Benno wrote:Do the 785's have secret buttons?
As far as I know only the DA 9070 levers so far
2023 Pivot E-Vault
2023 Pivot E-Vault
- Moderator
R785 levers dont even have extra ports
Using Tapatalk
oh lol weak. Although realistically I am never gonna use them so meh. And I guess as soon as they release a "DuraAce" model hydro disc then I will swap that in.
- tomyboy123
Now it is on Garmin to make the buttons work...
https://forums.garmin.com/showthread.ph ... Ace-Levers
If you go to dcrainmaker.com and look at his Edge 1000 review, he covers the Di2 integration and shows the fields that are available. I assume the look of those fields is the same on the 510.
http://www.dcrainmaker.com/2014/06/garmin-1000-depth-review.html
