TCR Advanced SL owners - carbon bars/stem?
RC856
by RC856
Hi folks,
Looking to see what carbon bar/stem combos people are using?
When I got my SL, I just the alloy stem as there didn't seem to be much available due to
the make up of the frame.
Has this changed?
I've been looking at shaving a few g's so wondered what the best weight to price ratio there was or is it all just really expensive?
Giant do their own versions but looking for stuff that might be lighter and fit.
Possibly EE brakes down the line if they would be that much better than my SR dual pivots?
Cheers
Richie
jeffy
by jeffy
you will need a 1.25 steerer. very much limiting stem choice. ritchey do some. year 2014 SLR Giant stems can be had for cheap(ish).
perhaps Giant integrated Aero bars/stem would be lightest?
RC856
by RC856
Hi,
So nothing's really changed with the choice available.
Yeah, the steerer....couldn't remember the dimensions!
Cheers
sharkman
by sharkman
In the meantime there are much more options available in 1 1/4" stems.
Non Giant would be ritchey, Syntace, Pro
But from Giant there are the contact 1 and 2 alloy stems (the last one has a good price/weight and comes with Ti. bolts).
Furthermore there is the Type 1 carbon stem (whichs is quite bulky and not too easy in combination with Ui2 and Di2 11v), the new carbon stem looks a bit more elegant (both come with a full carbon aero bar).
I like the looks of the Giant fixed carbon stem / bar combo but it's expesive and the disability tot tilt the bar made me decide against it.
sawyer
by sawyer
Zipp make one now
What is annoying is the shortage of 140mm and -17o options for 1.25
lannes
by lannes
I'm using Giant Gen 2 carbon stem paired with the FSA K-Force light compact carbon bar, I prefer the aero top, shallow drop and short reach.
shotgun
by shotgun
Brands suported are mentioned above. To check available options online, use the term "OD2" price wise Pro XLT and Giant Connect 2 seem ok on the weight/price category.
2018 Giant TCR Advance SL0 Disc
2017 Festka Scalatore
1989 Battaglin Roche
1985 Alan Carbonio
bungis
by bungis
sawyer wrote:What is annoying is the shortage of 140mm and -17o options for 1.25
Fouriers makes one:
http://www.fouriers-bike.com/en/pro.php ... &cid=7&f=2
acetonehk
by acetonehk
In fact you can find the 1 1/4" stem from Canyon online shop, because the CF SLX also uses the same standard.
sawyer
by sawyer
Fouriers makes one:
Thanks but my teeth are bad enough as is!
peted76
by peted76
Resurrecting this thread to ask the question..
Besides Giants own, are there any other 1.25inch/31.8mm integrated aero stem/bars available?
The Giant one to me, looks a bit fugly and the Canyon one looks quite large and rounded on the 'flat' part.
If not I'll just continue to lust over non-integrated bars/stem combo's.
junchen
by junchen
Ritchey has one, and zipp has one I believe.
Sent from my SM-G920I using Tapatalk
