Help needed!!! ZIPP VumaQuad cranks
Okay guys! It's been a while since I was last here...
Now, However, I find myself in a bit of a tight spot, and I must turn return here for your assistance with this issue:
So, my trusty Vuma quad crank set has been causing me some concerns, and it turns out that the 'aluminum spindle bolt' was worn out and came apart when I tried to tighten it with a torque wrench. It can be seen on page 3 in this link: http://www.zipp.com/_media/pdfs/manuals/vumaquad_%20manual.pdf
ZIPP can't help me, as the crank set is discontinued
My question is, if anybody has a ruined set lying around or know of someone who has that bolt lying around somewhere???
I really don't want to find another crank...
TY
TY
- G. Digital K. Loco
please help me
Just a wild idea but would something like this fit?
“I always find it amazing that a material can actually sell a product when it’s really the engineering that creates and dictates how well that material will behave or perform.” — Chuck Teixeira
I actually thought of that, too. They look the same diameter - but I will definately have to give it a go! Thank you very much!
Reason: no quote needed.
Juanmoretime wrote:#16?
EBay USA has a few for sale, cranks, should it come to that.
Yes, it is #16 I am referring to
I just ordered this bolt from FSA
They really look the same, so let's hope they are!
Yes keep us posted. I also use a Vumaquad that I love.
RippedUp wrote:Yes keep us posted. I also use a Vumaquad that I love.
Sure thing! I am expecting the bolt to turn up within a few days.
I gave up on them when 2 pairs I had the spindle started to separate from the spider. G/L!
You shouldn't have! I found a solution yesterday with an FSA bolt which is much more durable than the original one. I am in the process of finding the order-number on the bolt, and one of these days I will make a post, that explains the process in-depth.
Thank you all for your help and suggestions!
Reason: deleted the quote. Please use reply in such cases. thanks
Great that you now get more use out of them, especially for what they cost. Glad to be of help.
So! The repair of the crank went like this:
(I am referring to the chart on page 3 in this link: http://www.zipp.com/_media/pdfs/manuals/vumaquad_%20manual.pdf)
- The bolt used (16) is allegedly from a FSA K-Force crank from around 2010 - the newer ones might work too!
- You need to keep numbers 14, 15 and 17, as the thread on 14 is reversed on the ZIPP part, and not reversed on the FSA part.
- To loosen number 14, we used a set pliers with pointed edges (I have no idea, what they are called in english - sorry)
- Then we just replaced the bolt, and put it all back together.
The FSA bolt is a bit heavier and ,I guess, more durable than the ZIPP one.
I hope this can be of some help for others
Thanks a lot!
Thanks a lot!
We are trying to figure that out - we found the bolt in a drawer at the shop, so my mechanic is searching for the invoice
Reason: deleted the quote as this is a reply. thanks.
It looks like it's this one
http://cassons.com.au/IN_Product.asp?pi ... 00000000NH
http://www.bicyclestore.com.au/fsa-k-fo ... bolts.html
