Scott Addict Cannondale SISL2 Crankset Compatibily?
jooo
by jooo
ProEvoSLTeamHighMod wrote:You are trying to accomodate an 86mm shell, thereby requiring far in excess of a 115mm spindle; more precisely, you would need somewhere around a 128mm spindle... This is possible, as the MOUNTAIN spindle (which is compatible) is far longer, at 137mm on current SiSL2 variations.
The crank can be installed on bb86 or even BSA frames, the ISSUE is chainline!!!
AS ABOVE, the chainline will be all over the place and unlikely to work well.
edit: quote added for pagination
I thought current MTB cranks were 132mm? IIRC there have been 122, 128 and 131 spindles made in the past for older MTB setups.
eric
by eric
But then you'd have a MTB chainline and MTB Q factor.
jooo
by jooo
Obviously, I was simply replying to the post before about the 137mm MTB spindle which also happens to sum up the chainline issue quite well.
