Removing carbon outer plate on Campy 11 speed derailleur.
mrowkoob
by mrowkoob
Is it easy, and if so how do I remove the outer carbon plate on a campagnolo rear derrailleur (11 speed Record) ?
I want to sand and customize this part.
The unbearable wallet lightness of being a weightweenie
latman
by latman
I bet it is not easy , and there are only 1 or 2 grams to be saved .
mrowkoob
by mrowkoob
It´s for a custom paintjob, not weight saving ;-)
arthurf
by arthurf
Couple of other sites have an overview for older mech's and knowing Campag, it won't have changed!
http://autobus.cyclingnews.com/tech/fix ... wfix_deroh
http://www.raltech.co.uk/Prod_96-Inst-RMC-Campag.html
ferrarista
by ferrarista
It is pretty easy. On the 11 speed derailleur you need torx tool to remove the 2 bolts holding the carbon plate. There are some thin washers if I remember correctly between the pivots and plate. don't lose them.
