I am learning that tire widths are not all created equal.
When I got my Gran Fondo, i fitted Schwalbe one 28mm tires. they barely cleared the frame and the rear brake caliper (on top) and after about 7 miles the rear started rubbing on the frame.
I then fitted 25mm GP4000's which clear by quite a bit. I want to find something lighter than the 4 seasons that come stock.
Does anyone have any suggestions of a good fit? It gets kind of expensive to buy tires and find they don't fit.
I am running Reynolds Assault (17mm internal width).
Thanks!
BMC Gran Fondo Tires
you say you are looking for lighter but the schwalbe one 28 is 255g
http://www.schwalbe.com/gb/road-reader/schwalbe-one.html
and the 28 4 seasons is 250g
http://www.conti-tyres.co.uk/conticycle/ti%20grand%20prix%204%20season.shtml
jeffy wrote:you say you are looking for lighter but the schwalbe one 28 is 255g
So I not only bought tires that didn't fit, they were heavier too!
I ordered a set of Compass to try out.
Thanks
dogg wrote:i would suggest something like compass cayuse pass, or grand bois cerf in 26mm as a middle ground in size between the schwalbe and conti, they come in about 40g lighter than the 25mm contis as well. and should be true to size on the 17mm rims
the 28mm compass fit the bike and feel great on the road. thanks for the tip.
