Emonda SL geometry
BigPoser
by BigPoser
So I'm looking at several frames and one of them is the Emonda SL (size 56, H2 geo). Looking at the geometry, it seems to me that it's neither a race or a endurance geometry but something in between. The R3 is one of the other frames that I'm looking at (also a 56), and its geometry is VERY similar to the Emonda.
Will the geometry experts please chime in on this? What is it really?
Thanks in advance.
Brandon
russianbear
by russianbear
Pick the one that fits you better.
djconnel
by djconnel
The difference is about 2 cm of stem (the Emonda H1 is less aggressive than the Madone H1 but the H2's are the same, so only Madone is plotted here):
So there's plenty of in-between. 2 cm of stem isn't much.
If you want even more relaxed, it's an extra 1.5 cm or so of stem for the Domane standard geometry.
The key thing here is to not compare the same frame "size". When switching to a more "relaxed" geometry the best fit may well be a smaller frame with a more similar head tube but requiring a longer stem.
BigPoser
by BigPoser
djconnel wrote:The key thing here is to not compare the same frame "size". When switching to a more "relaxed" geometry the best fit may well be a smaller frame with a more similar head tube but requiring a longer stem.
I've often thought this could be a possibility. My thought was that the stem would just be an extension of the top tube, so to speak. In reality I'm probably in between sizes in most brands.
The Boardman SLS is another frame that I'm looking at.
