EW001 unit
- eliflap-scalpel
- Contact:
i have an issue with EW001 trasmitter unit.
not able to have it recognized by my Edge.
i have a custom set up: no shifters , only the climb shifter remote switch.
so road shifters (brakes+shifters) are mandatory to have EW001 working ?
a guy with a standard bike can unplug the shifters and see if it works on the Edge ?
http://eliflap.it/
- Pokerface07
Which Edge? And have you updated all the firmware in your Di2 system?
Twitter: @FormerTTchamp https://twitter.com/FormerTTchamp
- eliflap-scalpel
- Contact:
is a firmware issue ?
not checked which firmware i have
http://eliflap.it/
- eliflap-scalpel
- Contact:
grouk wrote:you need to activate it with etube and upgrade firmware, i want to buy one but i need to buy other stuf and i didnt find one site that sell everyting i need, where do you buy it?
i live in Italy, bought in a shop here.
there is 1 piece on stock
http://www.gloriotticicli.it/shop/gps-c ... eless.html
http://eliflap.it/
- Shop Owner
If you have the external front junction with the charger that plugs into it, you can update firmware at home. You will need to download Shimano's e-tube software first. Also make sure your Edge is fully updated. You didn't mention which Edge you have. If it's older, like the 510, the update for the eww is still in beta, last time I checked.
- eliflap-scalpel
- Contact:
i have edge 810 , in the 3.24 beta version
http://eliflap.it/
- eliflap-scalpel
- Contact:
a little step done.
update firmware of BCR2 . now EW001 is found.
but 810 in 3.24 beta version is crashing after few minutes ... created a page with battery level, gears ratio, rear gears , all data are zero ...
http://eliflap.it/
- eliflap-scalpel
- Contact:
http://eliflap.it/
- WheresWaldo
- in the industry
eliflap-scalpel wrote:a little step done.
Report this directly to Garmin.
- eliflap-scalpel
- Contact:
WheresWaldo wrote:Report this directly to Garmin.
mmm , i think to not do it.
i have a 1x10 set up.
the crashes are caused by my settings: i selected to show on the Edge the gears ( so including FD and RD )
but i have a 1x11 set up
removed it and selected only RD gears , it works flawless
http://eliflap.it/
- eliflap-scalpel
- Contact:
Garmin released the 3.28 beta version
fixed Di2 bugs
now it works !!!
http://eliflap.it/2014/11/07/risolti-i- ... min-e-di2/
fixed Di2 bugs
now it works !!!
http://eliflap.it/
