DI2 - not running through jockey wheel ??
ricey155
by ricey155
Help required I've tried adjusting but no success, when on small chain ring at the front and 28 at the rear it pulls away from the jockey wheel or slightly off
It runs but with a click it only happens in that gear everything else runs great, I've only noticed it lately doing some proper climbs and needing that gear.
Any advice ? I've replaced the hanger thinking maybe that was the issue but still no joy
Help :)
Sent from my 16gb Mi Pad (it works)
mattr
by mattr
Chain too short?
Top pivot spring jamming?
Got any pictures?
ross
by ross
Cassette spacer correct? Stiff link in chain?
upside
by upside
Bent derailleur hanger.
rma
by rma
Check chain line
Check the stop bolts
bikerjulio
by bikerjulio
Although I have no experience whatsoever with Di2, I'd think that a hard inner stop, via a limit screw would be a necessity, and if so would be the easiest thing to check first. It may be preventing the RD getting into the correct position.
Second would be the hanger alignment, already mentioned. Just replacing it is not enough, it should be checked with the right tool.
Has to one of those 2 IMO.
There's sometimes a buggy.
One.
ProEvoSLTeamHighMod
by ProEvoSLTeamHighMod
1. Hanger alignment - just b/c you replaced doesn't mean it's straight, a frame can be imperfect and new hangers are often not straight.
2. Assuming shifting is good in all other gears, verify the low limit is not too tight (IF HANGER IS STRAIGHT!)
goodboyr
by goodboyr
10$ Canadian on hanger alignment.
ricey155
by ricey155
Cheers for the replies I spent 2 hrs Saturday removing and tinkering :-) it has a brand new chain with 400 miles on it - I'm moving towards hanger
I rode with the club yesterday mine tends to look like it slightly towards the wheel where most are straight my SRAM red on the planet x is straight :( more spending
I'll video it later just in case its not that :)
kode54
by kode54
the cage itself may be bent even with a true aligned hanger.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
ricey155
by ricey155
Another 1hr this afternoon and after some major pulling and swaying it went crack and I thought the worst
And then no gears :( waggled it about in frustration and it works again in the 28 and 34 really weird
I tried to take a video but couldn't get the line right to view - I'm beginning to wonder if the cage is bent from when the original hanger failed 3000 miles ago and just got worse
goodboyr
by goodboyr
For the love of god.....just get a rd hanger alignment tool and check it already!
bikerjulio
by bikerjulio
I liked this bit.
One.
goodboyr
by goodboyr
At least he didn't use an automotive hydraulic press to install his bottom bracket ( apologies for the inside joke)
ricey155
by ricey155
Yes very caveman on my part :) - I'll invest in one asap - quick 50 today to see if all OK no doubt I'll get the dam click back
