RS685 Weight?
kingkongsfinger
by kingkongsfinger
Done two rides on them, 60 miles each. One word, superb. The hoods are so comfy.
Modulation is amazing, I race MTB's and use XTR brakes on both of my bikes, easily as powerful and probably a better feel than the XTR. (awaiting my titanium bolt up grade to be delivered.)
"I could have done this job myself in five minutes, but as things turned out I had to spend two days trying to find out why it had taken someone else three weeks to do it wrong."
MichaelB
by MichaelB
jeffy wrote:are all the component parts in the kit separate for install?
... also i have not seen any packaging but apparently it is lovely? any updates from those who have purchased?
My order from Bike24 came in the full Shimano box and all components were separate, so you can set up calipers how you want.
Only thing 'missing' from the kit was the bleed cup and gear cable outers.
Gavin929
by Gavin929
anyone know if the new br-rs785 calipers are the same color as the previous? do they match the ultegra group or the dura ace group better? the original seemed to be the same color as ultegra but the newer version seems darker and more likely to match the dura ace...
kingkongsfinger
by kingkongsfinger
Gavin929 wrote:anyone know if the new br-rs785 calipers are the same color as the previous? do they match the ultegra group or the dura ace group better? the original seemed to be the same color as ultegra but the newer version seems darker and more likely to match the dura ace...
This is a close up of the br-rs785 caliper on my bike.
elmar schrauth
by elmar schrauth
I never hit the banjo with my heel. Tcx Advanced, xt or xtr brake, Rotor 140mm.
jeffy
by jeffy
seem a bit heavy.
might have to tune the weight a little
jeffy
by jeffy
foofighter wrote:How is the performance? Worth the wait/weight? Who's using 140mm rotors?
are people using 140mm or 160mm? and at what rider weight?
ms6073
by ms6073
I think in many instances, this is dictated more by the frameset. Like most of the open mold Chinese frames, the height of the post mounts on my IP-105-D are too tall for anything but 160mm are larger.
- Michael
by Nefarious86
140mm disc, organic pads 85kg rider + bike etc.18% hill repeats. After today I will be trying sintered pads to see they cook things any less, will also be asking Specialized if 160mm rotors fall within waranty specs.
Using Tapatalk
