Building a single speed out of a road frame
MNX1024
by MNX1024
I'm trying to build a single speed out of a road frame that I have lying around. As a weight weenie, obviously I'm going to try to build it as light as possible. Here's the catch, I have absolutely no idea about parts from the single speed and fix gear world, and what is compatible or not. So, I would need some recommendations on parts and answers to some questions. Suggestions outside of my questions are more than welcome!
Before we begin, let me briefly list the parts I already have:
    2011 Defy Advanced frame set (uses BB86)
    Soul S2.0 Wheelset
    Planet X KCNC Brakes
    Easton EC90 TKO Handlebars
    WCS 4-AXIS Stem
What I still need are:
    Crankset
    Chain
    Brake Lever
    Spacers
    Cog
    Tensioner
Obviously the first question is, for the parts I still need, what are my lightest options? Concerning the crank, I'm adamant on getting one that uses only one chainring.
Is it necessary to even get an tensioner? If I can get away without one, I'd prefer not to use one so I may keep the weight down.
Concerning the stock rear derailleur hangar, in the case I do not need a tensioner, I would like to get rid of it. Where can I get a plate that will fill in the hole at the drop out?
Headset bearing cover, where can I get one with the least amount of stack height possible because I plan on slamming my stem.
Raineman
by Raineman
If you don't want to run a chain tensioner then you would have to look for an eccentric bottom bracket. I don't know of any in BB86 but you might be able to use a converter and then a threaded eccentric bottom bracket, I'm not sure if it would be lighter than a tensioner but it would certainly look better :D .
As for the rest of the drivetrain, I would look for 1/8 chain/sprocket as there are more options so you can probably find a lighter option than looking at 3/32.
kulivontot
by kulivontot
This is so 2007
dogg
by dogg
measure your chainstay length then go use google and figure out which ratios you'll be able to run without a tensioner.
MNX1024
by MNX1024
Thanks for all those that gave some suggestions. Looks like I won't be able to get away from the tensioner with the gear ratio I want....... At least I don't have to worry about replacing the rear derailleur hanger.
Anyway, any suggestions on some light weight parts, such as cranks and chains?
Which part decides the type of chain I should be getting, the cog or chainrings?
Out of curiosity, does 10/11 speed chainwork with single speed cranks?
kode54
by kode54
another solution is to run a White Industries eccentric hub...
https://www.benscycle.com/p-1522-white- ... speed.aspx?
others have mentioned an eccentric bottom bracket, like the Bushnell one.
hope that helps.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
mattyNor
by mattyNor
Do not run a fixed gear with a chain tensioner it's simply not safe. 3/32 chains (10/11 sp) will work as long as you buy the right chainring/cog but 1/8 set ups last significantly longer. The whiteindustries hub is your best option because it also gets closer to a proper chainline.
russianbear
by russianbear
Those WI hubs are the cleanest solution imo.
