SISL2 ...broken?
fifarafa
by fifarafa
Have you seen something like this? :evil:
SISL broken?
SISL broken?
CBJ
by CBJ
I have now.
fifarafa
by fifarafa
Is this broken? Do you have contacted with Cannon?
nicrump
by nicrump
and now we know the limits of what was once a beautiful crank. (SISL and SI)
mike
Resident Pro
by mike
similar thing happened to me on a very light crankset, the original sampson stratics crankset.
nicrump
by nicrump
was this possibly over torqued?
fifarafa
by fifarafa
Definitely not. It has been installed-a year ago- according to Cannondale instructions:
http://www.stagescycling.com/StagesCycl ... r_1012.pdf
NiFTY
by NiFTY
Can't even imagine how that would fracture there if it wasn't due to the crank bolt being torqued (even if only torqued to spec) That sucks. Surely that is a warranty job.
Phill P
by Phill P
don't ride it - take it back to the dealer
Technical Director at www.TUFFcycle.com
fifarafa
by fifarafa
If "the crank bolt being torqued" then these scratches/cracks should not occur immediately, and not after 3000 km?
After every ride I clean and check the bike ( frame and all components) and haven't noticed any crank damages before.
asv
by asv
I've had that happen twice to me, both times with my non-driveside arm. Crankarm installed with a torque wrench. After the first time I started torquing below the 40nm and it still happened.
topflightpro
by topflightpro
I have a really hard time believing you could over-torque it to create that kind of cracking. In would expect that the the bolt would break well before then - I broke one bolt well before I got anywhere near the recommended torque range.
fifarafa
by fifarafa
Cracks are in the weakest arms places. Cannondale maybe overdid with weight loss, maybe in these places the walls are too thin....or this is manufacturing defect.
BeeBee30
by BeeBee30
Check out what happened to my axle last week :( To be fair its a very old one, at least 10 years old.
Ti or dye!
ms6073
by ms6073
topflightpro wrote:I have a really hard time believing you could over-torque it to create that kind of cracking.
Ditto. I write that having once inadvertently over-torqued an SISL crank bolt resulting in the bolt head immediately snapping off, requiring some finesse to get the threaded part of the bolt that remained out of the spindle!
- Michael
