Weight Weenie Specialized S-Works Spider
Qman
by Qman
I thought people might be interested to see how I designed and built a weight weenie spider for a Specialized S-Works crank. So, I’ve shown some photos and brief descriptions below.
I purchased a used S-Works crankset from this forum. It had the graphics removed and both the carbon arms and the aluminum spider had been painted black. I decided that I preferred to see the carbon weave so I stripped the black paint off the arms and refinished them with a gloss clear coat. I loved the new look, but now the spider looked a little rough so I decided to strip the paint off of it too. Underneath the paint, the spider was a bit scratched. But more importantly, I found the stock spider too heavy (60g) and rather ugly. I’m not a fan of the specialized twisted shapes, and I don’t like the combination of carbon arms and silver spider. So, I decided to design and build a new spider to reduce the weight and improve the looks.
First, I measured the original spider. Then I created a 3D solid model of the spider to establish a baseline for the new design:
Then, I created a new design based on the original geometry, but changing the style to better match my Extralite chainrings:
And I created a second design for comparison:
I refined the two new designs and found that both of their masses were approximately 40g. Next, I compared stress and deflection between the three designs. I used a torsion load due to the chain tension, and a side load due to shifting gears. The design with the open holes had significantly higher stress and deflection. That design would be much easier to machine, and I like the looks of it, but I decided to go with the stiffer design.
Next, I programmed the CNC mill to create the design:
And machined the part:
The part after machining:
I polished everything except inside the pockets:
Then black anodized:
Final mass is 38g, compared to 60g for the original (sorry about the fuzzy photo):
Here it is mounted on the crank and the bike:
Total mass with bearings, shields, wavy washer, and chainrings is 535g.
I'm very happy with it. I think it looks much better and it's dropped a little weight. I've only just got it on the bike, but so far everything works perfectly.
dereksmalls
by dereksmalls
That is awesome! Brilliant work and only 1 gram heavier than the compact spider that Lightning make for their cranksets of the same design
Flyfishing3
by Flyfishing3
Props
520 Dan
by 520 Dan
Did you do the 3D modeling in solid works?
shimmeD
by shimmeD
BEAUTIFUL!
Less is more.
swiftvelo
by swiftvelo
Any chance you could make and aero model ? Something that works with praxis rings?
SLCBrandon
by SLCBrandon
You should sell these.....
Qman
by Qman
The modeling was done in Creo and the FEA was done in SolidWorks.
An aero model would probably be easier to machine overall, but the shape would be a little tricky under the arm - I think it would need a little extra clearance there.
Rick
by Rick
Awesome job!
jmpsmash
by jmpsmash
Incredible work.
j0oftheworld
by j0oftheworld
Those are beautiful!
JasonM. Tempe, AZ
'14 SW Roubaix / '16 Allez Sprint
njee20
by njee20
Good effort, that looks great!
F45
by F45
Every man's dream is to be able to do just this sort of thing in his garage. Very nice.
ITTY
by ITTY
Lovely work. As F45 said, this is exactly the sort of thing I wish I had more time and money for. Do you own the CNC mill, or do you have access to one at work/school?
Moloko Plus 6.24 kg
"We haven't located us yet"
PSM
by PSM
Pro!
