Sram Force hoods - year 2014
Champ5000
by Champ5000
Hi all
I need new hoods for my Sram Force levers - production year 2014.
I can see that there are several different hoods for Sram Force.
Shall the model bear the name "SRAM Hoods for DoubleTap Levers"?
Thanks
highdraw
by highdraw
The name you show has been around for years so isn't necessarily specific to 2014.
Best technique is to find the PDF service catalogue for Sram and obtain the part number for the hoods for 2014.
If you purchase by part number, you will be more assured of getting the right ones.
Sram Force 22 hoods are revised from previous design level so you want the correct design level.
Also watch for purchasing actual Sram OEM hoods versus aftermarket examples which may not fit as well or offer same level of comfort.
goodboyr
by goodboyr
Double tap are for 10 speed, for 11 speed you actually need the Red 22 lever hoods, according to the spare parts catalog. Just get the part number and any LBS can order.
https://sram-cdn-pull-zone-gsdesign.netdna-ssl.com/cdn/farfuture/1E2WqxxkcYXkk7El8fLceNe7wdxAyHTlKVfclLITs5Q/mtime:1409262053/sites/default/files/techdocs/2015_sram_spc_reva_0.pdf
Champ5000
by Champ5000
All
Thanks for the replys.
I have now ordered the right ones :-)
