Campagnolo Ultra-Fit seems to be the name campi uses for tubeless rims.
2-way fit is the name for rims that you can use both clinchers and tubeless
Q: Which campagnolo rims uses Ultra-fit and therefore can use tubeless.
It seems that 2-way fit technology will not be part of the 2014 line up.
Are the new Shamal tubeless?
I think you may be getting confused with Campag terminology. Ultra-Fit is the shape of the rim that's suitable for tubeless.
The wheels that are Ultra-fit compatible are also Two-way fit and can accept regular clinchers.
For 2015 the Shamal, Eurus & Zonda Two-Way Fit wheels are available which is the same as in 2014.
