So it has all worked perfectly and no issues, I last charged her about 2 months ago or so (was away for work for half of that) anyhow I thought I would top her up before racing this weekend.
Plugged in the charger green flashing light all good, put the magnet in, plugged her in.
Nothing.
Just the green flashing light on the charger... No other lights on the bike.
Tried without the magnet in also nothing. Connection is a good fit, pins all look clean.
My question is do I have a problem? (apart from the obvious list...)
A. It's fully charged you're sweet (it'll do that), pushing the mode button shows a solid green.
B. Off to the shop...
Campy EPS Charging isssue?
Just charged my V2 this afternoon.
LEDs on charger unit:
- steady green = unit is powered
- steady green + steady orange = charge in progress (orange goes off when unit is fully charged)
I've never seen blinking green on the charger unit. However, if your interface unit displays steady green when the mode button is pressed, unit is probably fully charged.
hmm so could be the charging unit at fault?
The unit would of been fully charged before i plugged it in... So I don't want to cross that bridge where it's not working at all
Edit: Looks like it's the charger viewtopic.php?f=3&t=123731
random101 wrote:hmm so could be the charging unit at fault?
When i had eps the charger unit had a fault, i got a new one, and everything were perfect again
EDIT: haha i was my topic you were reffering to
