Garmin mount for aero road bars (not TT bars!)
Weighing up what new bike to buy and while the Canyon CF SLX is on the list so is the new Aeroad.
I've noticed the handlebars on the Aeroad are aero (ovalised) in shape and i assume the normal Garmin Out Front mount wont fit as its for standard 31.8mm bars (assuming aero are fatter than 31.8mm, they are obviously not 31.8mm tall, there is no dimensions on the Canyon website however).
Anyone got aero road bars and use a Garmin mount out front of the handlebars, if so what?
viewtopic.php?f=3&t=28122&start=120
this thread
this thread
He sells them here.
http://edge-mount.bike/
Hello,
I have been to the listed web site and don't see a option for the Zipp SL Sprint stem. I don't see a place to ask a question or send a message to see if this will be an option in the future or maybe I'm just not seeing one?
He sells them here.
edge-mount.bike
Thanks for any help!!!
He sells them here.
edge-mount.bike
I'll grab one for the SL sprint stem in a heartbeat if I can get to them too!
I have the Sprint SL stem on order and using a standard K Edge mount which I guess will give similar problems when installing. Have you considered/tried the K Edge XL mount? It may look slightly odd but I don't like the Sram mount where it positions the Garmin above the level of the bars
If the bars don't a wide enough rounded mounting area, mounting a metal mount like the k-edge will make it cut into the bars. The sram mount that I'm using now will flex to accomodate the ovalised shape and yet doesn't tilt the unit too much. Mounting the unit above the stem is not ideal for me too but that had the advantage of allowing me space to remove and install the unit.
