Haero H.145 Bars
Not too much on the forum about this road handlebar. 150-160 grams, 31.8mmm Drop 132mm; Reach 82mm.
http://www.haero-carbon.de/produkt-121.html
Feedback,thoughts vs. others in the category?
That picture looks like the work of photoshop and not of a carbon process
- Stolichnaya
I need to bump this old thread.
I am more and more in need of some pressure relief on my hands and seeking another bar that is similar to my 3T Ernova, but perhaps lighter. The Haero H.145 RR SL seems to check a few boxes.
I am still struggling with the width / sizing differences and the Haero 420 seems caught in the middle for me.
(For reference, I use Ernova bars with a 120 stem and the ErgoSum with a 110.)
Does anyone using these bars have some comparisons / feedback on stiffness, comfort, real-world weight, cable routing cleanliness for the Haero road bars? (Photos of the underside routing path would also be appreciated.)
I have one having come from an ergonova. Great bar, similar shape to the ergonova but less reach, even though the geo on the haero website wouldn't lead you to believe this. Your stem will need to be about 10mm longer to maintain the same geo. My 42cm bar was 155g on my scales.
Size 38cm from Starbike - stuff enough at the drops for me but I don't do any spot of sprinting at all. The decals come off/gets scrapped ridiculously easy so you should just remove it. Pretty carbon weave, and the top is slightly ovalised like the ergonova. Cable groove is there underneath.
- Stolichnaya
Kayrehn, NiFTY, much appreciated.
If I pull the trigger, I'll go with a slightly longer stem.
In terms of width though, i seem to be stuck inbetween. The 44cm o-t-o Haero's apparently measure 43cm c-t-c, so can it be assumed the 42cm Haero's are 41 c-t-c at the Ergos?
Also, I assume the cable grooves are external and there is no internal routing - just an indent for tucking the housing unp underneath - correct?
Yes, it's just an indent-groove, with no holes for cables to go through and come out from the stem side.
Oh yah, the ovalised section is not as large as the ergonova too, in case that's important to you.
- Stolichnaya
Oh! That is actually very important! I appreciate the head's up.
I'll ask for their technical chart to review the width again.
Thanks.
Thanks.
Bumping and old thread here but Stolichnaya did you pull the trigger on these? How did you find them? I am also a fan of the Ergonova's and am looking for something similar, either these or perhaps the AX's. In regards to width my 3T's are 42 cm, so I guess the Haero's in 42s will be slightly narrower and the 44s slightly wider, yes? Oh one more Q....... are they 1K or 3K finish, thanks in advance.
BB
BB
BB
Coffee & carbon
Coffee & carbon
Schmolke now has "Ergonova": https://www.schmolke-carbon.com/product ... e-evo-tlo/ , if in market for a lightweight bar of that shape, I'd get that one and never look at another bar then.
- Stolichnaya
@beanbiken, no I never did get those Haero bars.
I reached the decision that the narrower width of the tops (in comparison to the 3Ts) was not to my liking.
@ mrlobber, the Schmolke looks intriguing!
- wheelsONfire
Size 44 is real size 42 (hood to hood 41.6cm centrum centrum)
Mine, weight 153g. Hm, you feel a much better stiffness using these with a stiffer stem.
I know because i have Extralite to. Otherwise you have to be more specific with your questions.
I can try to answer as good as i can.
Bikes:
Open *UP* (2016.04.14)
