Material used to protect carbon rails on Fizik saddles?
shinkansen
by shinkansen
I have a Fizik saddle where the protective cloth looking material wrapped around the rails has started to peel off... Rails are fine. I want to replace the protective material but not sure what to use. Is it just some type of cloth soaked in epoxy? Any suggestions?
boots2000
by boots2000
I removed mine. It was too tight of a fit for a carbon rail saddle on an Eriksen sweet post.
It worked fine with no tape on it.
DuncanS
by DuncanS
Yikes! Isn't its purpose to protect the carbon tubing from clamping forces?
BeeSeeBee
by BeeSeeBee
I think it's just scrim cloth to help prevent the saddle from slipping.
wilwil
by wilwil
It was on Fizik Kurve saddle I had and that had metal rails. It just went brittle and fell off.
stanseven
by stanseven
I think it's for both protecting rails from clamping and keeping the saddle from slipping. I was able to get a Cervelo clamp to work by clipping compressing the material. I checked it occasionally and there never was a problem.
