Help identifying Shimano PRO bar/stem
- harmonix1234
- Contact:
All I know is that all the PRO branded team sky stems are all custom in 1mm increments. You'll find a mixture of 129mm, 131mm, 123mm etc. Watch the GCN YouTube of the team sky tour bus. Chris' would be custom length. Prob why he can't stop staring at it. The bars I'm not sure. Pro vibe?
Strange they go for mm measurements given the dimensions could easily be offset by clothing, shoes, gloves (apparel), physiological conditions (nutrition, hydration) or indeed the environment.
In my estimation the error is around 5m before you start feeling the offset or discomfort in the fit.
- ultimobici
- in the industry
- Contact:
Originally frames were made to measure so stem lengths could cary by 10 or even 15mm. Now with many frames being monocoque the stem has to vary by smaller increments. As for 5mm variations being the minimum before one notices, try riding 30000km a year for a living before assuming that.Donkey wrote:Strange they go for mm measurements given the dimensions could easily be offset by clothing, shoes, gloves (apparel), physiological conditions (nutrition, hydration) or indeed the environment.
ultimobici wrote:Originally frames were made to measure so stem lengths could cary by 10 or even 15mm. Now with many frames being monocoque the stem has to vary by smaller increments. As for 5mm variations being the minimum before one notices, try riding 30000km a year for a living before assuming that.
Nothing to do with monocoque frames. It doesn't matter. There's more variation in same frame sizes between two diffrerent brands than even some arbitrary 5mm variation in say a stem.
I am referring to that earlier comment of 1mm variation in Pro stems. I say completely unnecessary.
Are they truly made in 1mm increments or are they simply the result of forging variations? Forged stems are not 100% assured of being of the stated length, unlike CNC'd stems that can be repeatably made to an exact length. I am not an engineer so I can't give you the engineering explanation, but I have heard it mentioned many times.
Ritchey stems are known to be forged with a margin of plus or minus 3-4mm. I have a fair number of 4Axis stems in 120mm and 110mm, and of the four I have of each length, none of them are all the same length. They are not different my more than 1-2mm but they are different, as I have measured.
I saw the same youtube video as harmonix and there is indeed a drawer FULL of stems factory-labeled in mm increments. Aside from the ones he calls out, I can make out 104mm, 111mm, 121, 122mm, and 125mm.
Whether or not the difference is perceptible, SKY has it:
http://www.youtube.com/watch?v=x87vzazC1oM&t=1m24s
- harmonix1234
- Contact:
Yep, that's the one ^^^
I too can tell the difference of as little as 2mm seat height or cleat adjustment, and also in stack height. If I change stem to 10mm difference it throws my whole fit out of whack. Same goes for 1 or 2° in saddle tilt, or roll of the bars and I'm just a fat commuter. Sure the difference between 110mm and 111mm might not be noticeable, but the difference between 110mm to 113mm, or 112mm to 117mm would easily be noticed I reckon.
Are you sure about the stems being custom made?
My guess would be that the stems are labelled with stack and reach. So a 120mm stem might measure 104mm reach etc. This would make it easier to setup bikes with the best combination of stem, bars, frame etc.
Danza wrote:They probably get a bunch of stock length stems but measure them and note their true length so its repeatable despite manufacturing variances.
Yep, I think you're right. I can't see Shimano/Pro doing custom forgings in these small increments for such small runs. Even if it is for the mighty Team Sky!
