di2 sprint shifter alternative
grouk
by grouk
hello
this is my first post i am from portugal, my english isn't so good so sorry for anything
i follow you guys a long time but now i need some help, im gonna start build my new bike, i received yesterday my shimano 6870 group, my intention is to mount some sprinter shifters but i dont like the shimano shifters, i whant some like cateye but i havê some doubts about the wiring
will be the shifters a normal on/off button?
if i get a similar conector plug two wires in a normal switch and plug in the lever in the sprinter shifter place it will work?
tanks in advance
aaric
by aaric
viewtopic.php?f=3&t=127059
The shimano sprint shifters are just a momentary switch. Closed when pressed.
grouk
by grouk
thanks is exactly that i want to do, now i have to buy a cable and cut it in half or get that type of conector
rmerka
by rmerka
To do that you're likely going to have to cut a wire off an existing sprinter switch. The connector for those is unique to the sprinter switch (SW-R610) and is proprietary to Shimano. It has a little tab on it that only fits into the special sprinter switch plug socket on 9070 and 6870 shifters. Good luck!
grouk
by grouk
i have the shifters here and i can conect every wire in every socket in the shifters
rmerka
by rmerka
Curious, which ones do you have? The reason I ask is if you have the climbing switch (SW-R600) the cateye buttons won't work because there is controller chip in that switch.
Sprinters SW-R610 (note the tab on the connector)
or Climbing SW-R600
grouk
by grouk
i though the sprinter button don't have plc ( controllerboard) only a normal switch
rmerka
by rmerka
The SW-R610, the first picture above has no controllerboard. The SW-R600, the bottom picture with two buttons, has a controllerboard in it which is why it's so big.
grouk
by grouk
Ahhhh ok what I want is the first one.do you confirm that it is a regular button on/off?
rmerka
by rmerka
That's my understanding that the SW-R610's are just simple switches and that they use the electronics in the shifters to do their work which why they have the special port on the switch.
aaric
by aaric
SW-R610's are just a momentary switch. I cut the wires on mine, and added a pair of cateye switches for the tops, and they work great. I also confirmed that shorting the two wires together while plugged into the sprint shifter port on the shifters causes shifts as part of the process.
You should be able to cut an etube wiring harness and plug them into the sprint shifter spot on the 6870/9070 shifters. It'd be pretty simple to test with a cut etube wire and stripped inner wires.
glepore
by glepore
Yeah, I think the tab is just to prevent you from plugging the switch into a port that doesn't have the support electronics.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
grouk
by grouk
glepore wrote:Yeah, I think the tab is just to prevent you from plugging the switch into a port that doesn't have the support electronics.
yes, i tink so, i will buy 1 cable cut half and conect two cateye button in paralell one in sprinter position and other in the climb position in each side of the handlebar
grouk
by grouk
for those who said it was not possible
http://www.dailymotion.com/video/x27p15 ... 1850_sport
just had to buy a cable cut it in half add switchs and configure software and its done
