Help troubleshooting reach adjust on Sram road levers?
peligro
by peligro
I bought a used road bike with ~2010 Sram Rival levers. The levers are in good repair and work flawlessly EXCEPT the reach adjust is not functioning properly.
On both levers, the reach adjust bolts turn freely but the threads are seemingly not engaging anything. I can turn them endlessly with no effect on lever reach. The bolts don't rattle and won't come out so presumably a circlip or something is holding them in place.
Anyone have a thought as to how to fix this? The levers are at what feels like their minimum reach, so my fingers are pinched while braking.
Cosmo
by Cosmo
Did you release the cable at the brake? (assuming you're moving the reach out) Reach tightens the cable, put some slack in the cable and see if the levers go out. Easy to forget the small things.
Don't forget the adjust the shift paddle as well-the two adjustments are independent of each other.
after 2 drinks I'm a loser, after 3 a star
