It is currently Tue Jan 16, 2018 11:10 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Fri Aug 29, 2014 9:00 pm
Even when I tighten the front brake (DA7900) it moves around but the part shown in red doesent .. whats wrong?
I tried with different length brake bolts at the right torque.
PostPosted: Fri Aug 29, 2014 9:18 pm
.. whats wrong?
Lack of mechanical skills ;-)
Only kidding dude, just my sense of humor, or lack of !
Seriously though, at a guess it could be the main brake centre bolt is bottoming out on the inside of the recessed brake nut before it takes up the play and tightens against the fork.
I would try a shorter brake nut just to be sure or very carefully remove a few mm's from the nut itself, maybe just 1 or 2 mil at first, or take to LBS.
Just my 2 cents worth ( ÔéČuro cents not USA cents )
PostPosted: Fri Aug 29, 2014 9:21 pm
I tried 2 different brake nuts and with 80% and 100% torque. The lock nut stays stable and the brake moves around the brake nut axle.
The lock nut can be loosened by the small allen nut at the top which I have tightened but still the same issue.
I am trying to make sense of this link atm: http://www.parktool.com/blog/repair-hel ... ke-service
PostPosted: Wed Sep 03, 2014 12:42 am
Take the brake off, thread the nut on and check there's no play. If the bolt is solid, use a shorter nut. It's not the torque, it's whether the lip of the nut is engaging with the frame before the nut reaches the end of the thread.
PostPosted: Wed Sep 03, 2014 1:31 pm
I took it to my LBS (http://www.fitzroviabicycles.com/) and they took the brake off and tightened the nut with an adjustable wrench and now its solved; works perfectly! :D
There are no new unread posts for this topic. Dura Ace 9100 front derailleur installation problems - can't shift into big ring
eric01
Sun Sep 24, 2017 5:36 pm
mlok View the latest post
There are no new unread posts for this topic. Chorus 11-speed front der. shifting issue
Catagory6
Tue Oct 24, 2017 12:21 am
AJS914 View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo brake issue
Tricky1
Thu Nov 02, 2017 11:10 am
jekyll man View the latest post
There are no new unread posts for this topic. Dura ace 7900 shifters with 9100 breaks ?? Compatibility
Allen254
10
1351
Thu Feb 16, 2017 10:40 pm
VforVonnegut View the latest post
There are no new unread posts for this topic. Shimano Hydraulic Brake Issue
CallumRD1
Wed Jun 14, 2017 1:25 am
CallumRD1 View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], Digger90, jever98, stevod, Wookski and 40 guests
cron
