Canyon AERoad CF 7.0 Di2 2013 Seatpost bolt
samwj123
by samwj123
Hi All,
Hopefully you can help me. I had a the bolt on my AERoad snap and leave half the bolt in the frame, I have managed to get it now. I had
contacted Canyon when this first happened and they kindly sent me a replacement frame as they were to busy to take the bike in for repair.
Like an idiot I misplaced the replacement seat clamp bolts that attach the clamp to the frame!
So I contacted Canyon again and they advised I would need to order a clamp to get the bolts which I did as it was completely my fault. Unfortunately the clamp arrived minus the bolts so I once again contacted Canyon and they said they would get the clamp/bolt sent direct from Germany and again it has arrived without the bolts.
Does anyone know where I can get replacement bolts, maybe an aftermarket alternative? they do not appear to be standard M-bolts.
If anyone can help that would be fantastic!
Stolichnaya
by Stolichnaya
Just ask Canyon what the bolt dimensions are - M(some number) X length plus you'll need to know if the bolt head is narrow, flat, rounded, etc.
Then you can find the bolts you need aftermarket in a number of places.
