Record EPS or mechanical Super Record 2015?
go electric. it is superior to mechanical and shifting does not tire your fingers. i notice my fingers actually get tired when i use the mechanical groups.
eps is more difficult to install than Di2 and is much clunkier in terms of wire thickness, not being able to choose just the right length you need, and battery charging (if you plug in the EPS charger incorrectly and damage one of the 5 pins, you are out of luck, whereas Di2 you just plug in your USB charger and voila). plus, if you happen to damage any of the wires off the EPS battery, you will need to replace the whole unit.
mike wrote:go electric. it is superior to mechanical and shifting does not tire your fingers. i notice my fingers actually get tired when i use the mechanical groups.
The wires was one of my biggest concerns as well. The mechanic at the bike store showed be the connector/wire set from EPS and he barely touched it and one of the plastic little clip on the end of the connector that snaps in just broke off. Compared to the Shimano ones they look very cheap and flimsy.
I mean he only but it in his fingers an it broke I watch him doing it and he didn't do crazy as this happened. He showed me that Shimano ones and they actually come with a little tool for the wire connectors. I really would stay with Campy for electronic as well but seeing that happen and hearing his experience installing both systems all the time and telling me DI2 is the way to go makes me wonder. They are also the ones who made me switch to Campy in the first place and I know they are not just trying to push Shimano.
Still, lots of great comments on this subject there.
yes, the little clips on the side of the EPS connectors can easily break. however, that does not affect the performance of the system. i used electrical tape after i made each connection so i wouldn't have any surprise unlinkages.
di2 is really the better system in terms of custom wire lengths, smaller wires, and charging (also, u don't need a "silly" magnet to turn off your system like EPS requires).
however, in terms of looks for just the shifters and rear derailleur, the carbon weave is more beautiful than the Di2 (unless of course, you have a UD carbon frame and Di2 fits the bill perfectly).
I did a 50 mile ride on Ui2 and compared to my old worn-out SRAM mix the Ui2 was a bit better in front shifting, but in rear it was insignificant. If my fingers were hypothermic maybe I'd feel differently, since it's less motion to shift. I see why people like it -- it's slick. But on this one ride it didn't make a significant difference. Maybe I'd feel different if I rode it for longer.
Front shifting with old SRAM is another matter. It usually works, anyway. Not an issue with 2015 Campy.
Thank You all for the posts.
I expected that majority of the forum will be for electronic.
As I wrote in the OP, I am a happy user of mechanical system. Actually there is no issue....no reason to go to electronic.
I have ridden the EPS few times.....well, I do not see any performance advantage over mechanical....even front shifting is "just OK"....I am not blown away but the performace of the EPS FD. Yes, it adjusts itself acc. to postion of the chain, but I do not see any difference in the speed and reliabilty of the small/big shifting.
Anyway, there are some nice features of the electronics which makes me think about it:
1) I like the EPS shifter body shape and the additional room for fingers between brake lever and bars (the shifting levers are smaller)
2) the set up is basically "install and forget"....no cable tension, no changing cables twice a season (I dont mind the battery charging)
3) the front der. adjusting itself acc. to position of the chain
4) the electronic is COOL
So, I am really stuck between Mechanical vs. Electronic .... I see EPS has some nice features but the price for this features is so much higher (mechanical Super Record groupset is cheaper than "just" Record EPS kit (no cranks, no brake callipers).
Buying the Super Record mechanical gives me NEW multi-option cranks (standard-compact chainrings).
If I decide to buy Record EPS, I will have to use my current cranks....honestly, I know myself....I will want the the new cranks = much more money spent
And finally, I am pretty much sure, Campagnolo will issue a new EPS next year. This fact is also important for me....I do not want to spent so much money to have an "outdated groupset for a full price"
Life is soooo difficult!
I've tried Di2 and EPS, and prefer EPS. But while both are certainly neat, I think the only reason any pro uses them for anything other than a time trial is purely because of sponsor pressure to promote their top-tier group sets.
Don't get me wrong, they shift flawlessly and easily, they are near-silent, and maintenance is great. But in terms of absolute performance, I still think mechanical campy beats EPS, purely on shifting speed. You can dump or pile-on much faster, and this is absolutely a measurable performance advantage on the vast majority of road courses... One for which I, at least, will happily suck up noise, an occasional missed shift, and periodic light wrench-time (the last being something I enjoy, truth be told).
I guess I view the current crop of electronic shifting groupos kind of how I looked at automatic Porsches back in the day. Up until the PDK dual-clutch automatic manual (read: automatic) was released, the standard manual transmission was just better. Trickier to use, but better. I think electronic shifting on bikes has some maturing to do. I think it's absolutely the future, but until they sort out the shift speed issue, I'll stick to mechanical. It's close though. I could eat these words by the next generation, who knows.
I also ride in hilly terrain, so dumping and piling is key. If I was riding mostly flats or time trials, where the ability to dump and pile isn't such a concern, I'd definitely be on EPS.
Oof.
I have never ridden either EPS or Di2 (I'm on 2011 SR on one bike and 10speed Record on the other), but my mechanic/ shop owner just came back from Interbike where he was able to ride 2015 mechanical SR, and he couldn't stop raving about it, especially the front shifting (and his usual bike is SR EPS). (and Starter, I agree with you about Porsches- I drive a 1995 993 with a 6 speed clutch!)
I don't know...when you change Di2 to the "Very Fast" setting from the default that sucker just goes up or down the cassette so fast the chain doesn't even engage each cog on the way up or down. It just fly's right through. I personally think the speed issue is a draw until I see a side by side video with a timer.
I have 2015 Sr. let me tell you mechincal is far from dead. It's spectacular in operation.
I build a lot of bikes with di2 and there is no way I'd take the di over the new SR.
more information
Galleries:
› Skunkworks #2 Colnago C60› Skunkworks #1
› Skunkworks #3 Colnago C59
› Skunkworks #7 NeilPryde
› Skunkworks #5 Speedvagen
› Skunkworks #8
› Skunkworks #4 Speedvagen
› Skunkworks #6
Nice!.
I'm still not convinced that electric shifting is the future of bicycling. Lol... shoot me. Stone me. Run away! Run away!!
- Similar Topics
- Replies
- Views
- Last post
- 27 Replies
- 2066 Views
Last post by GorrGrimWolf
Sat Dec 09, 2017 3:48 pm
- 29 Replies
- 2455 Views
Last post by TonyM
Wed Nov 01, 2017 5:29 am
- 0 Replies
- 375 Views
Last post by wilwil
Fri Aug 04, 2017 9:06 am
Campagnolo Record/Super Record 11 Rev + Medium Cage
by dudemanppl » Sun Jul 23, 2017 8:14 pm » in Road - 4 Replies
- 1093 Views
Last post by joeyb1000
Fri Aug 04, 2017 4:41 pm
- 5 Replies
- 340 Views
Last post by mike
Thu Mar 08, 2018 8:42 pm
