It is currently Tue Feb 28, 2017 8:54 am
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Wed Aug 20, 2014 4:22 pm
I am just wondering if anyone has had the Sram Powerlink become disconnected while shifting from big ring to small ring. I did search the topic but didnt come up with much for info. This has happened to me twice now within a three year period. The only thing I can come up with is the chain sucked up while shifting to small ring and was enough to disconnect the link. No harm was done and I found the one half of the link as we were coming to a stop. I never thought this was possible with quick links but apparently it is.
"Life is like riding a bicycle. To keep your balance you must keep moving"-Albert Einstein
PostPosted: Wed Aug 20, 2014 6:38 pm
the link is directional and if installed backwards it will do exactly as you describe.
www.crumptoncycles.com
PostPosted: Wed Aug 20, 2014 7:56 pm
If you take it off regularly the interface can get loose. No idea how it could come undone while riding though. It cannot however be installed backwards as mentioned by nicrump.
PostPosted: Wed Aug 20, 2014 8:08 pm
It happened to me once to my Rotor chain. I was just riding around in front of my house. The chain just fell off. Found half the link laying on the street. I bought a new KMC link.
Its possible that I never properly seated the link, but wouldn't it seat on its own when riding?
PostPosted: Thu Aug 21, 2014 1:48 am
If you break links and re-join regularly as part of your bike maintenance programme they can wear, so timely replacement is necessary. And while I haven't used ever type of 11 speed link on the market, the ones I do use are 'single use' only and are not meant to be re-joined once broken.
PostPosted: Thu Aug 21, 2014 4:47 am
Like they said, the SRAM powerlink is directional and for one time use. As far as I know, all the 11 speed links are one-time-use only unlike some of the 10 speed ones.
PostPosted: Thu Aug 21, 2014 5:46 pm
I rarely reuse the links and once its on I typically leave it in place. Its funny cause when you watch some of the videos on how to remove the links they usually fumble with the link trying to separate the two halves. The only thing I can figure is chain suck cause the link has to double back on itself to separate or at least that is how I separate them with the channel locks.
PostPosted: Thu Aug 21, 2014 5:57 pm
I re-use the "one-time use" links and have never had one fall out. If you use one of these or similar tool you can feel whether or not it's worn out by how it clicks into place.
http://www.parktool.com/product/master-link-pliers-mlp-1-2
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Thu Aug 21, 2014 6:57 pm
Being curious, I looked up the SRAM chain instructions, which make no mention of directionality.
Neither SRAM or KMC links are directional as far as I can tell.
Wipperman links ARE directional however.
I've used all types for years without an issue.
There's sometimes a buggy.
One.
PostPosted: Thu Aug 21, 2014 8:05 pm
SRAM Power Lock links have an arrow on them. The outer plate arrow is meant to point in the direction of chain travel. That means that when connecting the chain below the chsinstay, the LEFT link is in front of the RIGHT link.
Ps- I have since chosen to install all quick links in this fashion. I believe there was a Power Lock recall a while back, may have been due to this. Afterwards is when they started coming with the arrows.
PostPosted: Thu Aug 21, 2014 9:42 pm
OK I don't have a SRAM chain around to look at, and I was just going by their site info. Pic does not show an arrow.
Looks like this
https://www.sram.com/sram/road/technologies/powerlock
Now I see it. Looks like 11-speed only has the arrow
I understand from another forum post that both links have the arrow - in other words the links are the same each side, which would imply a certain symmetry. I'll try not to worry about it any more.
One.
PostPosted: Thu Aug 21, 2014 11:56 pm
it is most surely a direction problem. follow the arrow.
https://sram-cdn-pull-zone-gsdesign.net ... chains.pdf
There are no new unread posts for this topic. Quick link? (on a shimano chain.)
eaglejackson
11
816
Fri Jun 17, 2016 7:43 am
sungod View the latest post
There are no new unread posts for this topic. i-link issues
4ibanez
Mon May 09, 2016 1:32 am
drchull View the latest post
There are no new unread posts for this topic. Can you use a KMC power link on a 1/8 Izumi 1/8 chain
fozworth
Sun Dec 18, 2016 8:03 pm
fozworth View the latest post
There are no new unread posts for this topic. Attachment(s) TUNE AC 16+17 MTB Quick Release Set
addictR1
13
983
Fri Nov 11, 2016 3:32 am
TarugoKing View the latest post
There are no new unread posts for this topic. Quick question on BMC TMR02
addictR1
10
730
Wed Mar 30, 2016 6:06 pm
addictR1 View the latest post
Users browsing this forum: Bing [Bot], djcharlou, Google [Bot] and 33 guests
