It is currently Thu Jan 18, 2018 10:58 pm
Post new topic  Reply to topic  [ 34 posts ]  Go to page 1 2 3 Next
PostPosted: Sat Aug 16, 2014 1:27 am
I've got a bit free time over the summer and since I have access to a machine shop I figured I'd make something quick and fun for my bike. Hope this is the right forum.
My steerer tube is still uncut (commitment is a big and scary word), so I have a 20mm cone spacer and two 5mm spacers sitting on top of my stem. They're not load bearing and spacers are pretty easy to make, so I figured I'd make my own single-piece 30mm spacer out of some spare 6061 aluminum I have. Here are a few pics of the process.
Made a design in Solidworks based on some headset spacers I saw on Fairwheel.
Doing some basic FEA. The spacer should be able to sustain a normal load of 50lbf. I was concerned that it might snap while being held in the vice on the mill. I ended up making the pillars wider during fabrication anyway.
Rough passes.
Getting there.
Freshly parted off! Not shown: deburring, Scotch-Brite, polishing wheel.
First pass on the first cutoff - I was pretty nervous! Can't clamp it too hard that it crushes the spacer but I also didn't want the spacer flying off as soon as the end mill came into contact. Solution: sharp carbide end mill, lots of oil, and a slow power feed. Advanced a depth of 1/32" per pass. If anyone's interested I can talk about how I got the cutouts to be perpendicular to each other.
Fresh off the mill. Gotta do some finishing work.
Cleaned up and did some light filing.
Another angle.
Old setup. Note cone spacer. :(
That's simply too many grams.
That's more like it.
If nothing else, it looks lightweight :noidea: I'd like to make it black somehow, but I haven't really thought about it too much. Maybe I'll just run it naked for a while so people can ask me about it :D
Time spent:
Design: 30-60min
Fabrication: ~3 hrs
A bit about the bike: http://www.pedalroom.com/bike/2013-scott-foil-17104
It's kind of a fatty at 7.71kg.
Hope you guys enjoyed the pics!
PostPosted: Sat Aug 16, 2014 1:47 am
Nice job! That's a big ass spacer, though. Do up a nice flat one like the Ritchey one you have on the bike, and they'd probably sell like hot cakes.
6.24kg CAAD10
PostPosted: Sat Aug 16, 2014 2:26 am
Nice work. But you need to cut off that stem erection anyways. Second the make some small spacers. Do you have access to anodizing?
PostPosted: Sat Aug 16, 2014 2:42 am
Are you in Toronto and/or shop at Cyclemotive? Your old setup looks exactly like a bike I worked on this week.......
PostPosted: Sat Aug 16, 2014 2:45 am
Edit: should have checked your pedal room first........
PostPosted: Sat Aug 16, 2014 3:02 am
Thanks guys. I thought about anodizing it, but I'll have to ask around and see.
PostPosted: Sat Aug 16, 2014 3:50 am
Very nice! Wish I has access to machine shop tools...and the knowledge to use them.
PostPosted: Sat Aug 16, 2014 4:22 am
@kramnnim check your local community college. Budget cuts have killed a lot of shop classes at CCs but some may be left.
@deliciousc4ke nice work! I like how you ran FEA on it.
I used to have a small home made part on each bike but a couple recent bikes have not gotten theirs yet.
PostPosted: Sat Aug 16, 2014 5:03 am
Update: Just bought a Ti countersunk bolt from eBay. Gonna make my own top cap next week sometime!
PostPosted: Sat Aug 16, 2014 6:05 am
But why bother if u r simply going to put the spacer ABOVE ur stem??? U could save the same amount of weight by simply cutting the excess steertube.
em3
______________
PostPosted: Sat Aug 16, 2014 6:48 am
Well done on the design and fabrication side of things. But why not just cut the steerer? You'd save the weight of the spacer AND e weight of the cut steerer.
PostPosted: Sat Aug 16, 2014 7:04 am
I totally agree that cutting the steerer is the better solution in terms of both weight and aesthetics, but for some reason I can't bring myself to commit to cutting it. I don't really mind the unicorn-tube. This spacer, as well as my upcoming top cap, is just a fun project for my bike that won't kill me if I don't make something robust enough :)
I'll probably cut it eventually, and when I do I'll make a one-piece spacer/bearing cover combo to replace the Ritchey one I have now.
PostPosted: Sat Aug 16, 2014 7:28 am
Why not try making a one piece top cap/spacer unit, other then the large amount of machining it will require.......
PostPosted: Sat Aug 16, 2014 8:35 am
I admire the design and work, top marks. Having that much steerer sticking up though just seems borderline dangerous if you crashed or something.
You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer.
-- Frank Zappa
PostPosted: Sat Aug 16, 2014 4:06 pm
Not sure I understand why you don't want to cut it. If that stem height works, then just cut the sucker. Having the steerer stick out above the stem like that is just dangerous. If you crash, that thing can cause some serious damage.
Your design is nice, though. Why not make some shorter ones for under the stem. Do them in 5mm intervals and you'll have a nice set.
6.24kg CAAD10
There are no new unread posts for this topic. V3 EPS Updates Not Working Via MyCampy
RichTheRoadie
15
1503
Tue Dec 12, 2017 7:02 am
TonyM View the latest post
There are no new unread posts for this topic. 30mm Axle / BB Spacer with < 0.5mm height?
jbattermann
Tue Aug 08, 2017 6:36 am
sungod View the latest post
There are no new unread posts for this topic. Colnago C60 fork: are spacer under/ above the stem necessary?
TonyM
Mon May 22, 2017 3:17 pm
Calnago View the latest post
There are no new unread posts for this topic. 10 Speed Cassette on Shamal Ultra 2015 wheelset. Do i need spacer or not?
3Pio
Mon Oct 09, 2017 10:42 am
3Pio View the latest post
There are no new unread posts for this topic. Headset question
thebadgerboy1982
Sun Mar 12, 2017 11:21 pm
froze View the latest post
Users browsing this forum: Alpine318is, Baidu [Spider], bilwit, bm0p700f, dorin, Google Adsense [Bot], tokyodrift69, wheelbuilder and 48 guests
