Lighter Cable/Housing for Dura Ace 9070
- RChevalier
Any suggestions on lighter Brake Cables/Housing for the DA9070 Shifters + DA9000 Brakeset?
The provided Shimano cables/housing in the groupset weigh 191g. Just wondering if there are lighter alternatives.
Thanks in Advance to all.
Try the search function. There are plenty of great threads on this topic.
- RChevalier
I tried... plugged in light brake cables into search and it came up with 217 pages. I thought it would be easier to just ask.
Aican Bungarus. The entire setup weights only 83g. I run them and they're great. Just be careful with the cables that come with it. The ends fray and unwind very easily. Make sure to use a good, sharp cutter.
I would have to disagree on the bunagrus. On my evo, I twice had a fractured liner segment for my rear brake, which meant the segments were swinging on the cable, and the inner cable would then poke out through the segments as it frayed. I am still using AICAN in non-mobile segments, ie, where turning the bars has no effect - front brake housing and from rear brake frame stop to rear brake. The anodizing on the AICAN is also poor and lasts very little time before it starts to decay.
I would choose a segmented housing where the liner is not a structural component. Like alligator ilink or swift. I think ilink is a much more elegant solution, it is slightly heavier and take slightly longer to setup, but the anodizing is better and it won't eat cables.
And you can reuse it over and over again by just replacing the liner. Cheap.
You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer.
-- Frank Zappa
-- Frank Zappa
My experience of Bungarus was mixed.
Its not a bad system per se, but an internal installation, with some tight cable runs, SRAM (more susceptible to FD cable tension than others) plus powercords was a step too far. I found the first setup OK, but the minute you had to release tension (I had to sort out something on the BB) you almost always get a compromised liner when you put the tension back on the system
NiFTY wrote:I would have to disagree on the bunagrus. On my evo, I twice had a fractured liner segment for my rear brake, which meant the segments were swinging on the cable, and the inner cable would then poke out through the segments as it frayed. I am still using AICAN in non-mobile segments, ie, where turning the bars has no effect - front brake housing and from rear brake frame stop to rear brake. The anodizing on the AICAN is also poor and lasts very little time before it starts to decay.
I haven't seen any of these issues with my set. Maybe you received a defective set.
My Aican housing's color has totally faded away, the anodizing is really awful.
Otherwise they function well on my bike, no better or worse than traditional housings. Despite the fact that my handlebar's internal cable ports cause the housing to bend very tightly, the links are still intact.
drainyoo - it has happened to me with 2 different sets - one shift and one brake. Each set of cabling that has failed (Rear brake to frame and FD shifter to frame) has failed twice - ie eaten 4 inner cables.
I'm not saying that my experience will be universal - i know that the high cable tension of my SRAM Yaw FD with put my FD outer at a higher risk than those using FD which run lower cable tension. Likewise the rear brake routing on the evo is terrible and causes sharp bends, but none of this has happened with alligator, which is also finished much more nicely.
I am still using my AICAN for front brake and from frame stop to rear brake where it has been fine. (No movement when turning bars).
I also used an AICAN segment as a spacer in the rear brake stop on the headtube of my evo, so the ferrule for the i-link cabling was supported over its whole base rather than at one single point.
- RChevalier
Don't let this stop the discussion but I just wanted to thank everyone for their input, I have a much better idea now which direction to head.
Although I must admit, my first experience with "bungarus" took me to a place I did not wish to visit...
I went with Ashima Reaction on my latest Di2 build. https://fairwheelbikes.com/ashima-react ... -4193.html
Less fuss than segmented, but still a weight decrease over stock. I couldn't tell a significant difference in brake feel. Perhaps a slight bit rougher pull, but hard to say for sure.
Not as light as segmented, but with an internally cabled frame, I didn't want to have rattles/aluminum wearing holes in the frame. Weight was somewhere between stock 6870 cables and iLinks IIRC.
- Similar Topics
- Replies
- Views
- Last post
- 7 Replies
- 1426 Views
Last post by MXGimp
Tue Sep 12, 2017 3:24 pm
- 2 Replies
- 722 Views
Last post by LeviR
Wed Jul 05, 2017 7:29 pm
- 10 Replies
- 542 Views
Last post by Braavos
Wed Feb 14, 2018 6:09 am
Shimano FC-R9100 crankset with 9070 Di2 front derailleur
by Bigger Gear » Tue Jul 11, 2017 8:46 pm » in Road - 5 Replies
- 1009 Views
Last post by lobuxracer
Mon Jan 29, 2018 7:30 am
- 12 Replies
- 885 Views
Last post by JoO
Sun Feb 11, 2018 4:29 pm
