It is currently Mon Jan 23, 2017 3:52 am
Post new topic  Reply to topic  [ 45 posts ]  Go to page Previous 1 2 3
PostPosted: Fri Aug 22, 2014 7:45 pm
They just emailed me new information on their site, including graphics.
Best regards
PostPosted: Sat Aug 23, 2014 12:13 pm
It was up on there website - Now it's gone.
I think I remember it being 278 GRams for the CRank arms and Axle - Isn't that 30-40 grams lighter than the old Clavicula? Add some Bearings/cups/rings - wouldn't that put it solidly under 500 Grams?
PostPosted: Sat Aug 23, 2014 2:18 pm
More importantly, I hope they reduce the Q-Factor from the Clavicula model.
PostPosted: Sat Aug 23, 2014 6:51 pm
I think it said the Q factor is 148mm so 4mmm narrower than before.
And the new crank is good for 120KG.
PostPosted: Sat Aug 23, 2014 10:15 pm
I manage to get the pdf in my phone.
Will upload it later or tomorrow:
Weight 287g
Qfactor 148mm
Chainline 43,5mm
Internal width 118mm
Total weight (bike+rider+apparel) 120kg
Graphics are gray and small.
PostPosted: Sat Aug 23, 2014 11:11 pm
Weird they include the bike mass in the limit.
SRAM Red claimed by Art's is 512 grams for 50-34 BB30:
http://www.artscyclery.com/Sram_Red_22_ ... RECB2.html
That's without bearings, clearly.
They don't have a weight for the 110 BCD GPX, but if the delta is the same as the 130 mm, it would be 564 grams.
But SRAM Chainrings are heavy. They got bit early in SRAM Force days with flexy, but weightweenie friendly rings.
126 grams for the 50:
http://www.artscyclery.com/Sram_Red_Yaw ... 0110B.html
But only 28 grams for the 34 (very nice!)
http://www.artscyclery.com/Sram_Red-For ... 3411B.html
That's 154 for the rings, taking the crank w/o rings down to 360 grams.
So looks like this one saves around 73 grams relative to the BB30 SRAM, 125 grams relative to the GPX SRAM (using delta below).
Note SRAM claims 557 for BB30 and 609 for GPX.... but that's 130 mm BCD:
https://www.sram.com/sram/road/products ... d-crankset
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Sun Aug 24, 2014 7:37 am
The THM bearings if unchanged will weigh about 93~94gm.
So these will weigh about ~380g including BB, excluding chainrings. My compact Clavicula's came in at ~415-420gm without rings if my memory served me correctly.
PostPosted: Sun Aug 24, 2014 6:50 pm
SRAM Red rings are 154 grams. My Praxis 46/34 are 139 grams (way heavier than I expected, BTW). These are top-shifting rings. The total with the Praxis would be 520 grams + bolts. Still impressive! My Lightning with SRAM Force rings is 581 grams.
Fuji SL/1
PostPosted: Mon Aug 25, 2014 12:55 pm
I'm just guessing here, but they might be trying to keep things consistent with how they calculate the weight limit for their brakes.
"Nothing compares to the simple pleasures of a bike ride," said John F. Kennedy, a man who had the pleasure of Marilyn Monroe.
PostPosted: Wed Aug 27, 2014 5:57 pm
New pics on R2bike.de Facebook.
Availability in March and April of 2015.
Best regards
PostPosted: Thu Aug 28, 2014 5:18 pm
60 grams lighter than the current Clavicula classic. That means with a BSA bottom bracket, chainring bolts, and Praxis rings the complete setup should be 495 grams. Using Extralite rings the complete setup should be right at 460 grams. Clearly the lightest on the market, but it will come at a price. Expected to be about $1700 USD.
Q-factor is indeed reduced to 148mm. We're expecting to see the first ones in April.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Fri Aug 29, 2014 12:29 am
Wow. So is that in compact or 130BCD? What BB configs do they come in?
2012 BMC SLR 6.02kg http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=110390
PostPosted: Fri Aug 29, 2014 8:44 am
Image is 130mm
Compatible with all BB types
PostPosted: Fri Aug 29, 2014 2:50 pm
For bb standards, it's important to note that it's not compatible with all, but is compatible with most. It works with most common bb standards with one major exception, it is not for bb90 which unfortunately eliminates Trek bikes.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Fri Aug 29, 2014 10:31 pm
Look good! Not sure I can see Trek continuing with BB90 for much longer - so many cranks that work with all BB designs except BB90!
There are no new unread posts for this topic. Attachment(s) Eurobike 2016
[ Go to page: 16 7 8 9 10 ]
Tillquist
137
20419
Thu Sep 08, 2016 2:19 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. Crank Length
[ Go to page: 1 2 3 4 ]
cyclespeed
51
2045
Wed Sep 07, 2016 7:16 am
cyclespeed View the latest post
There are no new unread posts for this topic. New Easton crank...
uraqt
Wed Jul 13, 2016 11:29 pm
wiRIDEfast View the latest post
There are no new unread posts for this topic. Campagnolo/BBRight Crank Help
Ste_S
Thu Apr 21, 2016 4:08 pm
em3 View the latest post
There are no new unread posts for this topic. Attachment(s) Crank arm fell off. [thm clavicula]
KCookie
41
2770
Thu Dec 01, 2016 5:08 pm
qorwlch View the latest post
Users browsing this forum: 2old4this, eyedrop, Klaster1 and 35 guests
