Thm Carbones - New Crank at Eurobike????
elfuinha
by elfuinha
Hello
Anyone seen this...
https://www.facebook.com/25817970103570 ... =1&theater
Best Regards
jooo
by jooo
elfuinha
by elfuinha
Any info?
Thanks best
Regards
logy
by logy
More info needed. This looks lighter than a Clavicula.
mythical
by mythical
I already thought the M3 was a step in the right direction but I really like what THM did here! :beerchug:
“I always find it amazing that a material can actually sell a product when it’s really the engineering that creates and dictates how well that material will behave or perform.” — Chuck Teixeira
RideWert.com
Wert Cycling on Facebook
kode54
by kode54
+1
removed that quote for ya! Please use reply in such cases. Thanks!
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
Mattias Hellöre
by Mattias Hellöre
Did I see it right? THM replaced the alloy spline clamp in the left crank to carbon?
THM M3 was a step into right direction but the weight increase was not.
Experimental Prototype
Ypsylon
by Ypsylon
The M3 wasn't supposed to be lighter.
The new one is called Clavicula SR and will be shown at Eurobike.
"Nothing compares to the simple pleasures of a bike ride," said John F. Kennedy, a man who had the pleasure of Marilyn Monroe.
sedluk
by sedluk
How much does it weigh?
I don't really care for the lock ring on the M3, it looks like this new crank uses the same lock ring.
solarider
by solarider
5 bolt circle. Soooo 2013!
Seriously, looks great, but with so much weight behind the new 4 bolt 'standard' (Shimano, Campagnolo and FSA), won't 5 bolt look quickly outdated, and (if the performance and weight hype is to be believed) seriously outclassed in performance terms?
Wingnut
by Wingnut
I agree...5 bolt looks outdated now...
"It's not the destination...it's the ride!"
Mattias Hellöre
by Mattias Hellöre
I personally do prefer 5 bolt, of several reasons.
One of them is stiffer crankarm/chainring connection.
Better load distribution.
4 bolt does look modern today, but are it better?
Frankie - B
Administrator
by Frankie - B
Eventually the consumer will give the answer. Remember the mtb sti shifter from shimano?
Wingnut
by Wingnut
I don't think the consumer will get the choice...the top three manufactures will eventually faze out the five bolt...
kode54
by kode54
sedluk wrote:I don't really care for the lock ring on the M3, it looks like this new crank uses the same lock ring.
its really the preload adjuster. non-drive arm has 2 bolts to clamp down.
