The new ee brakes
greentimgreen
by greentimgreen
Any ideas where the little coloured plastic 'badges' are available from? No reference on the ee brakes website or Fairwheel yet.
2014 Parlee Z-Zero DADi2 & ENVE (6.2kg)
2015 Colnago C60 RSWH Campag Chorus & Mavic SLR (c.7kg)
Gearjunkie
by Gearjunkie
I ordered black brakes and they came with black logos installed and extra grey logos in the box.
nagge
by nagge
Any one that has some more riding impressions of these brakes? Thinking of getting a pair for my Tarmac to replace the BR9000. Only thing thats holding me back besides the fact that no one seems to stock them in EU is the adjusting between different rim widths which seems more time consuming than "normal" brakes.
SuperSix EVO III Ultegra 8070
spdntrxi
by spdntrxi
I'm still playing with the pull to get them to feel the way I like.. The rear I have dailed in.. The fronts I'm close... I can see how changing wheels and adjusting might be a little more time consuming.
The brakes themselves are top notch and work just as good as .. If not better in the modulation dept then my da9000.. Which are great brakes too
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
wojchiech
by wojchiech
nagge wrote: Only thing thats holding me back is the adjusting between different rim widths which seems more time consuming than "normal" brakes.
On my bike with EEs I switch between 20mm and 23mm wide wheelsets. I use the thickest pad spacers, and set the brakes up according to the wider 23mm rims. When I switch to the thinner wheels, I just use the barrel adjuster to compensate for width. I usually have to tighten about 1/3 of the barrel threads. I set up the brakes with the barrel adjuster all the way in so I have plenty of slack. If you run wheels with a greater difference in widths (ie 19mm training wheels and 26+mm race wheels), you might have to switch out the pad spacers.
nagge
by nagge
Ok that sounds reasonable. Just need to find someone i europe that stocks them, any suggestions are appreciated.
Rippin
by Rippin
Keep an eye on Starbike, They come in somewhat regularly.
http://www.starbike.com/en/ee-cycle-works-eebrake/
____o
_`\<,_
nagge
by nagge
Yeah I have Starbike and dulight on email notice cant find anyone else in europe that has them on their site.
sugarkane
by sugarkane
Order direct from the web site ?
Bogan
by Bogan
^This. I did this for my last set of ee's.
MAMIL? Never. O.F.I.L. yeh! (Old F**ker in Lycra)
nagge
by nagge
I just assumed they were us based? Ill have to give that a go otherwise.
Rippin
by Rippin
If you are considering ordering outside of EU, then Fairwheel Bikes in the US has them in stock.
https://fairwheelbikes.com/ee-cyclework ... -1048.html
____o
_`\<,_
stephen@fibre-lyte
by stephen@fibre-lyte
nagge wrote:Ok that sounds reasonable. Just need to find someone i europe that stocks them, any suggestions are appreciated.
Ubyk in the UK are stocking them, I'm led to believe that their first batch were sold very quickly but they are due to receive a new batch in around a week.
http://www.ubyk.co.uk/eebrake-mrk3-2015-by-ee-cycleworks/21232
not sure if the currency exchange rate will be very favourable right now though?
nagge
by nagge
They are about €130 more expensive compared to Starbike :/
wheelsONfire
by wheelsONfire
nagge wrote:They are about €130 more expensive compared to Starbike :/
Yes Starbike has a very attractive price (+ that shipping is free of charge for EE). If you ad shipping fee and taxes on top from US to EU, you'll find that Starbike is actually cheaper than any US based seller!
Ubyk also sell the earlier versions, so you should check (if you buy from them) that your order those marked mk3.
If not, you'll buy the older version.
Complete set of EE mounted vs DA 9000 mounted, is - 110grams.
Bikes:
Open *UP* (2016.04.14)
