New Fulcrum Racing Zero Carbon's?
morrisond
by morrisond
http://racingzero.fulcrumwheels.com/en
What is the point of these wheels? Only 60 Grams lighter at 1358 than Zero Nite Clinchers at 1428 which will probably brake better.
Is Fulcrum not getting a Version of the new Bora's? The New Bora 35 is onluy about 1170'ish Grams.
Are these going to be a lot less expensive than Fulcrum Bora's?
Is Campy getting a version of this wheel?
Same Bearings and I would assume internals between them all.
LionelB
by LionelB
Interesting, seems to be a new carbon rim different than the bora 35. Not sure of the width of it either.
morrisond
by morrisond
They say the new 30MM rim is wider on the Fulcrum site - 1268 grams in Tubular.
5 8 5
by 5 8 5
Site says 17C versus 15C for the alu wheels. Sure i read they were 23mm?
