shortening ti bolts
PoorCyclist
by PoorCyclist
What is the best way to shorten a ti bolt by 2-3mm?
Does it work well with grinder or sander? I would think Ti is a little softer than steel sonit should go quickly
Frankie - B
Administrator
by Frankie - B
I've always used a dremel for that. works perfectly. make sure to clamp the bolts in some wood in a vice. they get hot!
eric
by eric
Bench grinder. Dip in water frequently to cool.
natiedean24
by natiedean24
I'd agree with bench grinder. If you happen to have an old nut that matches the threads, put it on before hand. When you're done grinding, unscrew the nut off the end and that will help correct the cut threads at the end of the bolt.
eric
by eric
I never remember to put a nut on first, so I usually grind the corners off the threads at roughly a 45 degree angle. That gets most of the burrs and deformed threads.
weeracerweenie
by weeracerweenie
Well ideally a lathe and thread file or die. That would get you a perfect result... But dremels work too
I guess there's worse hobbies than making a bike light? Right?
5 8 5
by 5 8 5
I use a combination of spacers / washers with a nut on the end to get the desired length of thread.
I then use a dremel with cutoff disk to shorten the bolt and then file down any sharp threads left on the end.
