It is currently Mon Jan 22, 2018 9:52 am
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Thu Aug 07, 2014 9:09 am
Anyone know if it is possible to extend the cables on the sprint shifters and mount them on the top of the bar, instead of the climbing switch? For a more clean look. And then mount one in each side to shift up and down. Last Question, where do you plug the shifters in? At the junction box or at the shifter?
Hope you can help me out :D
PostPosted: Thu Aug 07, 2014 9:51 am
If I remember corectly this setup was actually used by Purito. Here is the link and good photo on cyclingnews.
Sprint shifters have to be connected to the levers, because they have a special port only available in the levers. They are also missing the "brain" unlike the climbing buttons or shifter levers, so basically they cannot function on their own. There is one port in each lever, so you have to connect one sprint button per lever - no way how to connect both to one lever.
Trek Madone 7s 60 H1
Trek Emonda SLR H1 Campy Record
PostPosted: Thu Aug 07, 2014 11:26 am
Thanks :-) that was actually what i want to do,
Just Like in the picture :-) just on the other side, so i can you both of my thumps. I will order some and see if they are long enough or i do have to extend the cables. :-)
PostPosted: Thu Aug 07, 2014 12:24 pm
I bought some sprint shifters with the same idea in mind. The cables are fairly short. They are long enough to put the button in about the middle of the top of the bar. Because this is where me fingers normally went I decided against it. I wanted to put them nearer to the center of the bars where I could reach them without moving my hand but not under my fingers. However, there are only 2 wires so you could easily solder n a extension in the middle of the wire. However, I sent them back because they don't work with 6770 shifters.
PostPosted: Thu Aug 07, 2014 3:43 pm
someone here on the WW forum did that. placed the buttons on the underside of the bars close to the stem. i believe that the attached cable is long enough to reach to the special plugs on shifters.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Thu Aug 07, 2014 5:15 pm
If you are going to cut/solder anyway, skip the official shimano sprint shifters.
Simply buy a standard long EW-SD50 e-tube wire, cut it in half, solder on a Cateye remote button to each end (or any momentary switch of your choice), and plug into the sprint shifter port on your 6870 or 9070 shift levers. Use a short length of 30mm heat shrink tubing to hold the button to your bars.
Shimano wants you to believe that the plugs for sprint shifters are different from the standard e-tube, but they aren't.
cateye buttons:
https://www.performancebike.com/bikes/P ... 28__400128
PostPosted: Thu Aug 07, 2014 5:20 pm
easy way to do this is to splice some cateye remote buttons in. There's a thread here somewhere about doing it. It's pretty simple soldering, as there are just two wires to connect to.
PostPosted: Thu Aug 07, 2014 9:50 pm
No, the length of the sprinter shifter cables are not long enough to place them close to the stem (true for both 7970 and 9070) for my 40 cm handlebars. You still need a pair of shimano sprint shifters since you need the plug that connects to the brake lever. You can do what a few of us have done; use a soldering iron to add a second pair of switches that goes on top of the handle bar. The original one goes to the drops as originally intended. :-)
On day long trips, my main shifters are the switches on top of the bars. I love 'em.
PostPosted: Fri Aug 08, 2014 4:54 am
This sounds ideal. Do you have any pics of your setup or can you explain in more detail?
Sent from my iPad using Tapatalk HD
PostPosted: Fri Aug 08, 2014 6:32 am
Your right Ltoddokc this sounds ideal... I'm the king with a soldering iron ( :D ), I will def put a picture up, when i'm done. But a picture would be great 2old4this? :)
PostPosted: Sat Aug 09, 2014 1:35 am
I am out on vacation but will be back next Saturday. I'll post pictures then.
Though there is not much to doing it. Simply cut the wires, strip a small amount, solder the tiny wires, unsolder them (cause I forgot to put the shrink tubes first :twisted:), re-solder and shrink the tubes. That's practically it.
Oh BTW, I had to add about 2" extra wire to the switches on the top. If you're like me, who prefers the switches very close to the stem, you'll need that extra length of wire.
Having said all that, there is an alternative....
On a second bike, I took out the plastic casing of the 610 and spray painted the switch. :twisted: it seems to be watertight.
Either way, shifting on top of handlebar rocks....
PostPosted: Sun Oct 12, 2014 5:54 pm
any news ? are yuo still on holidays ?
http://eliflap.it/
There are no new unread posts for this topic. Bar tape wrap with Di2 sprint shifters, advice needed
motorapido
Wed May 31, 2017 10:04 pm
motorapido View the latest post
There are no new unread posts for this topic. Zipp SL Speed v SL Sprint
Shrike
Wed Mar 01, 2017 10:57 am
Shrike View the latest post
There are no new unread posts for this topic. 2018 Allez Sprint: which color?
Thenuge
31
3506
Wed Sep 20, 2017 10:40 pm
Nefarious86 View the latest post
There are no new unread posts for this topic. Pro vibe sprint stem decal removal
TomColnago
Thu Feb 09, 2017 11:23 am
TomColnago View the latest post
There are no new unread posts for this topic. Fetha mount on Zipp Sprint stem?
SpecializedColnago
Wed Apr 19, 2017 3:53 pm
SpecializedColnago View the latest post
Users browsing this forum: caballero, micky, Monkeyfudger, Squashednuts and 24 guests
cron
